loading
Step 5: Making Legs and Carrying Handles
The legs of the stove are usually meant to be short, as to be able to easily look into a pot or pan on top of the stove from a standing position. Any design may be accepted for personal preference, as long as it is able to support at least 100lbs and withstand high temperatures. For this stove, small lengths of C-channel were used to make a sturdy base. Weld the legs to the tank before going any further; when the tank is full it is very heavy. Another feature that may be added and/or altered on the stove are the carrying handles.
<p>nice innovation</p><p>good luck</p>
<p>AJMansfield -- who cares what they are called. Pickey, pickey, pickey.. Looks like he used a &quot;Stick&quot; welder in the first place for the risers on top, so that make the wells there, (I hate to say it) TACK WELLS.......... Old Stick Welder</p>
<p>Very Nice Rocker Stove, I made something similar without the stand out of a mini beer keg. I'm thinking about making a bigger version out of a full sized beer keg. </p><p><a href="https://www.youtube.com/watch?v=aM7yvHa8GWg" rel="nofollow">https://www.youtube.com/watch?v=aM7yvHa8GWg</a></p><p>-GearsNTools</p>
<p>I'm sure he means tack welds. In the end though, it doesn't make much difference what he calls it since there is a more than adequate picture.</p>
<p>Need for ashes emptying in case os indoor setting... how you will go about with a permanent setting? Maybe a center cone with a bottom gate or something similar...???</p>
<p>Bbecause this one doesn't exhaust through a flue, I'll keep looking for a different design rather than build this one for indoors. If I could get the gases outside I'd still worry about sending too much of my heat through the flue with a rocket style stove.</p><p>For what this is, though, and for its intended purpose, kudos to the poster!</p>
<p>Those are not spot welds attaching the risers to the stove. A spot weld is when you use two metal electrodes on opposite sides to weld pieces of relatively thin sheet together. You used either FCAW or SMAW, not RSW. (As you have already welded the top on, there is no way to reach the interior to perform a spot weld anyway.)</p>
Excellent Plan. Can this be made so that it portable? Smaller cylinders possibly with the same base concept? I like your design but am looking from some thing that is &quot;BOB-able&quot; <br> <br>What are your thoughts about making the components nest-able (contain within each other for transport and storage? <br> <br>Also-- Do the interior walls get a full load of Pearllite? (up to and below the pressure relief drilled holes? <br> <br>Awesome
Nice plans and design. Impressive. You may be interested in the rocket-style-with-a-twist space heater we have been making for our workshop. It is made from scrap materials and burns long sticks/branches. Its on our blog <a href="http://www.floweringelbow.org" rel="nofollow">FloweringElbow.org</a>
Nice desigh and beautiful workmanship, but I don't understand where the initial wood smoke/gas is being recirculated into the flame. Please explain what I am missing... <br>Thanks.
I think some folks are thinking of rocket mass heaters when they see this and confusing the 2 a rocket mass stove just burns hotter and faster than a regular stove for cooking a rocket mass heater burns and re burns wood gasses for a greater and longer heating time with less fuel and burn time !
Great looking stove! <br>I would caution all against using vermiculite as insulation for something like this. Vermiculite has a small amount of asbestos in it. Not a good thing to be releasing into the immediate environment where you might inhale in into your lungs. <br>Cheers!
I notice a lot of guys using pearlite <br>
regardless of weather it fits the bill to be considered a rocket grill or not, I love this idea &amp; wish I had the knowledge &amp; tools to build one. <br> <br>I thank you for sharing Sir, I love this thing!!!
I don't understand how this is a rocket stove. There doesn't seem to be anyway the secondary gases can join the flame. It appears to me to be a very nice insulated wood stove.
From my understanding, the length of the chimney, approx 3 times the hieght of the burning chamber, will be long and hot enough for complete combustion of all the gasses.
I second your question. <br>
Amen to that !
It's great, keep up the good work.
I'm afraid while it may appear like a rocket stove, unfortunately if I am correct, the similarity is only skin-deep. It's a just very nice stove, well constructed. Rocket stoves have certain characteristics, which are essential to performance [efficiency and low emissions], a design that departs significantly from those characteristics means it isn't one and it will most probably be not as efficient. IIRC, there are stoves which are not of the <em>rocket</em> type which achieve similar or greater efficiencies, but are much harder to construct. Rocket stoves are intended to be very simple to make.<br> <br><br> <br>See the 'Ten Design Principles'<br> <br>The Rocket stove was invented by Dr Winiarski at the Aprovecho Research Centre.<br> <br><br> <br>References<br> <br>Design Principles for Wood Burning Cook Stoves<br> <br><a href="http://bioenergylists.org/stovesdoc/Pcia/Design%20Principles%20for%20Wood%20Burning%20Cookstoves.pdf" rel="nofollow">http://bioenergylists.org/stovesdoc/Pcia/Design%20Principles%20for%20Wood%20Burning%20Cookstoves.pdf</a><br> <br>Designing Improved Wood Burning Heating Stoves<br> <br><a href="http://bioenergylists.org/stovesdoc/apro/Heat/Heating%20Stoves%20LO-RES.pdf" rel="nofollow">http://bioenergylists.org/stovesdoc/apro/Heat/Heating%20Stoves%20LO-RES.pdf</a><br> <br>
I definitely agree with you that it is a bit of a deviation from the rocket stove design. I wanted to feature an inner chamber so that it may function like a rocket stove if you want, but it may also function as a forge. <br> <br>The addition of a removable platform plate in the feed tube helped it to function like a rocket stove so that a draft could go underneath long sticks, and the material burned hotter and more efficiently with even less smoke. The inner chamber was added to the stove so that after getting some hot coals in the chamber from burning sticks, charcoal could be added to the chamber if forging applications were desired. <br> <br>Also, thank you for the references they were great to look at.
i look forward to hearing a response from the author on this, because the understanding of several folks who've commented here mirrors mine: This doesn't appear to actually function like a rocket stove.
Hi, <br>I made something similar, to melt aluminum which used a hair dryer to create the air blast, instead of convection. <br> <br>The problem I had - sparks coming out the top. No smoke, but LOTS of sparks. I deemed my project a failure due to the fire risk. I never got to melt aluminum with it. :( I toasted a few marshmallows with it, though. <br> <br>Based on your experiences with this type of stove, which is a sort of &quot;self-blasted&quot; furnace, please comment on these questions: <br> <br>1. How did you address the spark issue? Does it make many sparks? <br>2. Have you checked for sparks AT NIGHT when you can see them up in the sky? <br> <br>Thanks!
At first it may seem that the stove produces lots of sparks, but once some hot coals form in the inner chamber the smoke dwindles to barely any and the sparks also die down. <br> <br>I agree with what rallen71366 said, using uncompressed charcoal briquettes make great heat.
I've managed to melt aluminum in a coffee can w/hair drier, and you're right, there are a LOT of sparks at first. I found that using a hardwood charcoal (Kingsford (tm) was a good brand) got hotter, quicker, and had fewer sparks. The cheap charcoal was held together with a lot of binder and filler, and produced a lot of ash, sparks, and sometimes wouldn't get hot enough to melt. <br> <br>If you have access to knot-free hardwood, and a method to cut it into fist sized chunks, you might investigate making your own charcoal. <br> <br>The old steam locomotives used &quot;spark catchers&quot; to keep from setting everything ablaze. I believe it was just a heavy gauge screen, across the exhaust stack, and far enough from the burner to keep from melting.
While this is a nice cook stove and good quality work, I don't think it would qualify as a rocket stove since a true rocket stove takes advantage of the gassification process of the wood. This is the process that enables them to be truly efficient and produce the low smoke output. <br> <br>The gasses are recirculated into the fire in a manner that there is enough heat and oxygen present to ignite the remaining flammable gasses left in the inital burn smoke. When those gasses and particulates ignite it burns away the majority of the normally wasted material and produces an extremely efficient and hot fire with less material.
It does work similar to what you described above. It produces little smoke to no smoke when the fire burns hot and plenty of hot flame.
So why only sand? <br> <br>Why not vermiculite or perlite? If it was to insulate then perlite or vermiculite would work better. <br> <br>Ash seems to work well too. Sand would just seem to add extra unneeded weight. Perlite, vermiculite, or ash would all reduce the weight of the finished project. <br> <br>
Next time when I make a more portable version, I will be sure to put something lighter inside.
Nice to see one completed and not looking like it has been thrown together out of scrap metal. <br> <br>A quick question, most of the designs I have seen have a platform for holding the fuel off the bottom of the feeder which allows the air to pass unobstructed under the fuel to feed the flame, not necessary? <br> <br>Also have you seen the gravity fed fuel hoppers where you can drop sticks down and the tips slowly burn, apparently good for controlling the speed of the burn. Is that something you considered for this build and dismised, or is it very difficult to get set up correctly? <br> <br>I have seen some filled with concrete + vermiculite/perlite mix. Seems like a lot more work than just filling with perlite but might hold the bits in places better. <br> <br>I like this and I have access to a scrap metal dealer and a welding set. <br> <br>If anyone needs me this weekend I will be in the Emergency Department.
Jislizard, <br>I recently made a removable feeder-platform plate and it made it easier to burn longer sticks and scrap woood. <br> <br>Also I had considered the angled fuel hopper but decided against it due to the fact that sometimes I may want the stove to function more like a melting forge than a stove, and the angle may make it harder to pump air into the inner chamber.
A great little stove! <br> <br>Might I suggest that you use only three legs as the fourth leg makes anything (stool, table etc) wobble. <br> <br>Obviously make them equi-distant (120 degrees) apart. <br> <br>Same for the pot supports, just use three instead of four. <br>
I know what you mean, if I ever make another I will consider 3 legs.
My only concern is that is looks a bit &quot;tippy&quot; being so top heavy. How does it handle getting bumped?
It seems ok when it gets bumped, the legs were made very sturdy. Before lighting the stove I always make sure it's on level ground too.
Another wonderful device that moves me forward to getting off the grid. I love the idea!! Now to build one and see it in practical use. Thanks eaahnen!! Keep it up...!! <br> <br>...Todd
Nice job! Looks great! I did mine in the style of a backyard grill.<br> <br><a href="http://www.instructables.com/id/Rocket-Grill/" rel="nofollow">http://www.instructables.com/id/Rocket-Grill/<br> <br><br> <br>&nbsp;</a>&nbsp;A friend of mine builds a lot of rocket stoves and wood gasifiers and LOVES using old propane tanks. They are nice metal, well-suited for projects like these.
Very nicely done. &nbsp;It ought to last a lifetime (or two!)<br> <br> I wonder, though, at the use of sand to fill the void between the shell &amp; the combustion chamber. &nbsp;If perlite, vermiculite or some other type of lightweight &amp; non-combustible insulation were used instead, the resulting structure would not be as top-heavy, have greater insulating effects and less heat transfer to the outer shell, which would lessen the risk of burns to the user.
...or wth a filler at the top, and a tap at the bottom, you could boil water with it!! <br> <br>See Kelly Kettles for details <br> <br>http://kellykettle.com/ <br>
I like it, sooner or later I'll make one too!
Very good work!<br> <br> Reading your intro I understant why <a href="http://www.instructables.com/id/CNG-tube-salamander-stove-salamandra-de-tubo-GNC/step13/Ruge-it-roars/" rel="nofollow">my stove &quot;roars&quot;</a>.
Great Work!!! I like it.
About This Instructable
302,741views
389favorites
License:
More by eaahnen:Fabricating a Heavy-Duty Rocket Stove
Add instructable to:
