loading
loading
Face detection and tracking with Arduino and OpenCV
Picture of Face detection and tracking with Arduino and OpenCV
UPDATES
  • Feb 20, 2013: In response to a question by student Hala Abuhasna if you wish to use the .NET Serial class, use the naming convention "\\\\.\\COMn" and replace n with a number > 9 to define your com port for COM ports above 9 such as COM10, COM11, etc.
  • Mar 23, 2012: Featured on Adafruit's Blog
  • Mar 23, 2012: Featured on Interactive Design
  • Dec 13, 2011: Featured on Floss For Science
This guide will also be maintained on my blog http://techbitar.blogspot.com/2012/04/face-detection-and-tracking-with.html
INTRODUCTION
In this project I have assembled a face detection and tracking system. You can see the video of the final project here:
Basically, the webcam sends video frames to OpenCV running on a Windows PC. If OpenCV detects a face it will track it and calculate its center's X,Y coordinates. The coordinates are then passed on to the Arduino via a serial USB connection. The Arduino controls the movement of the webcam with the help of two pan/tilt servos to follow the detected face.
OpenCV (Open Source Computer Vision Library: http://opencv.willowgarage.com/wiki/) is an open-source library that includes several hundreds of real-time computer vision algorithms. The OpenCV 2.x library is a C++ API.
This is an integration project between hardware and software tools. The image processing C++ code samples are provided with the openCV library and all I did was to modify the sample code for this project. I removed some of the unnecessary code and added serial communications to it so it can send X,Y values to Arduino.
CREDIT
This project would not have been possible without the team who developed OpenCV. I also benefited from Ryan Owens' tutorial (http://www.sparkfun.com/tutorials/304) which is based on Processing, OpenFrameworks, and an earlier version of OpenCV. I tried to install Processing and OpenFrameworks with no luck. So Instead, I opted for Microsoft Visual C++ 2010 Express and the latest version of OpenCV which is 2.3.1 without any middleware or wrappers.
TOOLS
Software Required
Arduino IDE 1.0 for Windows
OpenCV 2.3.1 SuperPack For Windows
Microsoft Visual C++ 2010 Express SP1
Serial C++ Library for Win32 (by Thierry Schneider)
Code Required
- OpenCV C++ (attached) techbitarFaceDetection.cpp (based on OpenCV's example facedetect.cpp)
- Arduino's (attached) cam_servo.ino (based on Ryan Owens' example SerialServoControl.pde)
Hardware Required
- PC preferably running Windows 7 SP1. The faster CPU the better.
- Arduino Uno or compatible + power source.
- Standard servos X 2.
- Webcam w/UBS interface.
- Breadboard.
- Jumper wires.
- Hobby wire to tie pan/tilt servos and webcam together.
1-40 of 61Next »
There is one thing you'd have to correct in the part of code where COM port is identificated: if (arduino_com->connect("\\\\.\\COM13", 57600, spNONE)!=0). Usually, arduino drivers organise virtual COM's with numbers more then 9. For correct OpenFile function working you should use \\\\.\\COM13 and not just COM13.
tlaiho21 days ago
I try to make this Arduino Open CV tutorial for webcams. OpenCV 3.0
RC1 is compiled and installed. I also use Code::Blocks 13.12 as IDE. I
am a newbie what comes to OpenCV and I do not know too much about
Arduino either but here I am learning. Arduino IDE is 1.7.2. This
tutorial is made for Windows 7 and software for this OS but I bet it is
possible to repeat this in Ubuntu Linux 14.04 also.
When I try to compile and run the techbitarFaceDetection.cpp
the Code::Block IDE gives me following error:
fatal error: Tserial.h: No such file or directory
So please tell me what to do next and how to fix this error.
So, I have a question.
Arduino is just rotating the stepper motor, right? All the processing is done via C++ serial port...It's not a portable project unless I use RPi...
elanthi3 months ago
The face tracking works well, but im stuck on making the servo rotate. I cant figure it out why it doesnt rotate. I changed the COM port on my COM3, but still no result. Any help would be greatly appreciated. Thanks
Can anybody help me out with this problem?
1>facedetect.obj : error LNK2019: unresolved external symbol "public: void __thiscall Tserial::disconnect(void)" (?disconnect@Tserial@@QAEXXZ) referenced in function _main
1>facedetect.obj : error LNK2019: unresolved external symbol "public: int __thiscall Tserial::connect(char *,int,enum serial_parity)" (?connect@Tserial@@QAEHPADHW4serial_parity@@@Z) referenced in function _main
1>facedetect.obj : error LNK2019: unresolved external symbol "public: __thiscall Tserial::Tserial(void)" (??0Tserial@@QAE@XZ) referenced in function _main
1>facedetect.obj : error LNK2019: unresolved external symbol "public: __thiscall Tserial::~Tserial(void)" (??1Tserial@@QAE@XZ) referenced in function "public: void * __thiscall Tserial::`scalar deleting destructor'(unsigned int)" (??_GTserial@@QAEPAXI@Z)
1>facedetect.obj : error LNK2019: unresolved external symbol "public: void __thiscall Tserial::sendChar(char)" (?sendChar@Tserial@@QAEXD@Z) referenced in function "void __cdecl detectAndDisplay(class cv::Mat)" (?detectAndDisplay@@YAXVMat@cv@@@Z)
in the "techbitarFaceDetection.cpp" file you will include your Tserial files.
If you check, probably you will see that the only included file is Tserial.h
by adding #include "Tserial.cpp" you will solve this problem . This is how i solved mine
Lakartoza5 months ago
Thats so... CUTE :D
SurayaN5 months ago
Hi, thank you so much for your helpful instructions. It really helps me. I am now at the step of OpenCV & Microsoft Visual C++ Integration and I referred to the link OpenCV 2.3.1 and Visual Studio 2010
http://www.deveature.com/2011/11/24/opencv-2-3-1-and-visual-studio-2010/
I saw your comment there where you had problem with “Cannot find or open the PDB file”. I am now having the same problem. May I know how did you solve it?
Thank you so much for your help.
i fixed it using this solution - http://answers.opencv.org/question/12600/problem-in-debugging-cannot-find-or-open-the-pdb/
swapyuee1 year ago
Thanks for very instructive steps. I have made it and it is so cool.
AlishaA swapyuee6 months ago
Hello there...buddy i need to know some thing from u
dada87 months ago
Hi,
I'm trying to do the project with Code Blocks instead of Visual Studio.
Like a lot of people, I have an error with tserial.h: "undefined reference to Tserial::Tserial().
I've added the library to the path. Do you have any idea of the problem?
Thank you very much!!
sinao1 year ago
Hi, in the arduino file`s "#include"(i`m new on this), in your code, i don`t see what`s included anywhere. Can someone help on this?
Thanks
Hi, i don't know what i need to make serial communication between c++ and arduino. I download Serial C++ Library for Win32 (by Thierry Schneider), I found sertest2.cpp, tserial.cpp and tserial.h, but i don't know where i have to put or include them and i don't know if there is another configrations needed. please don't skimp on the advice.
put all of them in your project folder..
dbin din1 year ago
Thanks for the tutorial..After countless hours testing, i made it..pheww..
anyway, to avoid error, don't forget to put Tserial.cpp and Tserial.h in your project folder..that should fix LNK2019 problem i guess..
hmm, bounding box issue?
roskostyle1 year ago
I have everything wired up, fixed the Tserial issue, fixed the LINK2019 and TBB_dll issues. Now I am gettign this error message.
The program '[10936] techbitarFaceDetection.exe: Native' has exited with code -1073741701 (0xc000007b).
I am stumped. Does anybody have any idea why this is happening?
vivaroma1 year ago
it would cause a little bit trouble if you are doing with 64-bit system. because C++ 2010 express could only compile with *64 compiler which is contained in Windows 7.1SDK. SDK always fail me.
Btw it for me the servo were run too slow.. not as fast as it is in the video.
Anybody here know how to make the servos run smoothly?
Yow all if you have problem with TSerial 'LPCWSTR' Error...
See this link.. http://stackoverflow.com/questions/3924926/cannot-convert-parameter-1-from-char-to-lpcwstr
I got it fixed :)
As many other people, im having troubles with implementing the library Tserial, By Thierry Schneider. Can anyone please clarify how to make the library work?, as many of us, im getting the conversion to "LPCWSTR" error.
i.Sneh2 years ago
Where to make change for port and baud rate in Tserial.cpp Help me ...
LGProspects2 years ago
Hey OP,
I have tried for countless hours today to get this to work but to no success. I can't get the visual/openCV part to work. I think I have narrowed it down to:
1) Not ever using visual studio or openCV before
2) Not being able to "run" visual studio
I would be extremely grateful for the instructions from the arduino code to the point of using the visual basic program.
Thanks!
roskostyle2 years ago
Hello, I was wondering what the specs on the servo motors are? and possibly the best place to purchase them.
khowsrow2 years ago
hey m not able to send X & Y coordinates to arduino uno using the same code with correct com ports and baud rate....can u suguest me where i m going wrong...
gbt2 years ago
Hello,
I'm getting following error in Visual Studio 2010
Error 2 error C2664: 'CreateFileW' : cannot convert parameter 1 from 'char [10]' to 'LPCWSTR
CreateFileW function is in WinBase.h(c:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Include\WinBase.h)
please help...
sakir19902 years ago
In your face tracking project I get errors about Tserial.
I used :
-Microsoft Windows 7 Ultimate SP1 32-Bit
-Microsoft Visual Studio 2008 Professional
-OpenCV2.3
-Tetraedre Serial Library(Tserial.h and Tserial.cpp)
-Arduino UNO R3
-Pan tilt mechanism
-Web Cam
errors ;
1>main.obj : error LNK2019: unresolved external symbol "public: void __thiscall Tserial::disconnect(void)" (?disconnect@Tserial@@QAEXXZ) referenced in function "int __cdecl _main(int,char const * *)" (?_main@@YAHHPAPBD@Z)
1>main.obj : error LNK2019: unresolved external symbol "public: int __thiscall Tserial::connect(char *,int,enum serial_parity)" (?connect@Tserial@@QAEHPADHW4serial_parity@@@Z) referenced in function "int __cdecl _main(int,char const * *)" (?_main@@YAHHPAPBD@Z)
1>main.obj : error LNK2019: unresolved external symbol "public: __thiscall Tserial::Tserial(void)" (??0Tserial@@QAE@XZ) referenced in function "int __cdecl _main(int,char const * *)" (?_main@@YAHHPAPBD@Z)
1>main.obj : error LNK2019: unresolved external symbol "public: __thiscall Tserial::~Tserial(void)" (??1Tserial@@QAE@XZ) referenced in function "public: void * __thiscall Tserial::`scalar deleting destructor'(unsigned int)" (??_GTserial@@QAEPAXI@Z)
1>main.obj : error LNK2019: unresolved external symbol "public: void __thiscall Tserial::sendChar(char)" (?sendChar@Tserial@@QAEXD@Z) referenced in function "void __cdecl detectAndDisplay(class cv::Mat)" (?detectAndDisplay@@YAXVMat@cv@@@Z)
I'm going crazy, Why I get this errors? Please give me an answer..
Thanks, Good works.
jmartizero2 years ago
Sorry in Visual C + + sends me this error when compiling in x64.
I do not understand the error.
Help me please. :)
Settings made of OpenCV: http://siddhantahuja.wordpress.com/2011/07/18/getting-started-with-opencv-2-3-in-microsoft-visual-studio-2010-in-windows-7-64-bit/
Program error:
1>------ Operación Generar iniciada: proyecto: camara_prueba_no1, configuración: Debug x64 ------
1>Compilación iniciada a las 01/12/2012 07:58:24 p. m..
1>InitializeBuildStatus:
1> Aplicando tarea Touch a "x64\Debug\camara_prueba_no1.unsuccessfulbuild".
1>ClCompile:
1> Todas las salidas están actualizadas.
1> camara_prueba_no1.cpp
1>camara_prueba_no1.cpp(95): warning C4244: 'argumento' : conversión de 'double' a 'int'; posible pérdida de datos
1>camara_prueba_no1.cpp(96): warning C4244: 'argumento' : conversión de 'double' a 'int'; posible pérdida de datos
1>ManifestResourceCompile:
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: void __cdecl Tserial::disconnect(void)" (?disconnect@Tserial@@QEAAXXZ) sin resolver al que se hace referencia en la función main
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: bool __cdecl cv::CascadeClassifier::load(class std::basic_string,class std::allocator > const &)" (?load@CascadeClassifier@cv@@QEAA_NAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) sin resolver al que se hace referencia en la función main
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: int __cdecl Tserial::connect(char *,int,enum serial_parity)" (?connect@Tserial@@QEAAHPEADHW4serial_parity@@@Z) sin resolver al que se hace referencia en la función main
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: __cdecl Tserial::Tserial(void)" (??0Tserial@@QEAA@XZ) sin resolver al que se hace referencia en la función main
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: __cdecl Tserial::~Tserial(void)" (??1Tserial@@QEAA@XZ) sin resolver al que se hace referencia en la función "public: void * __cdecl Tserial::`scalar deleting destructor'(unsigned int)" (??_GTserial@@QEAAPEAXI@Z)
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: void __cdecl Tserial::sendChar(char)" (?sendChar@Tserial@@QEAAXD@Z) sin resolver al que se hace referencia en la función "void __cdecl detectAndDisplay(class cv::Mat)" (?detectAndDisplay@@YAXVMat@cv@@@Z)
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: virtual void __cdecl cv::CascadeClassifier::detectMultiScale(class cv::Mat const &,class std::vector,class std::allocator > > &,double,int,int,class cv::Size_,class cv::Size_)" (?detectMultiScale@CascadeClassifier@cv@@UEAAXAEBVMat@2@AEAV?$vector@V?$Rect_@H@cv@@V?$allocator@V?$Rect_@H@cv@@@std@@@std@@NHHV?$Size_@H@2@2@Z) sin resolver al que se hace referencia en la función "void __cdecl detectAndDisplay(class cv::Mat)" (?detectAndDisplay@@YAXVMat@cv@@@Z)
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: __cdecl cv::CascadeClassifier::CascadeClassifier(void)" (??0CascadeClassifier@cv@@QEAA@XZ) sin resolver al que se hace referencia en la función "void __cdecl `dynamic initializer for 'face_cascade''(void)" (??__Eface_cascade@@YAXXZ)
1>camara_prueba_no1.obj : error LNK2019: símbolo externo "public: virtual __cdecl cv::CascadeClassifier::~CascadeClassifier(void)" (??1CascadeClassifier@cv@@UEAA@XZ) sin resolver al que se hace referencia en la función "void __cdecl `dynamic atexit destructor for 'face_cascade''(void)" (??__Fface_cascade@@YAXXZ)
1>C:\Users\marti_000\documents\visual studio 2010\Projects\camara_prueba_no1\x64\Debug\camara_prueba_no1.exe : fatal error LNK1120: 9 externos sin resolver
1>
1>ERROR al compilar.
1>
1>Tiempo transcurrido 00:00:03.71
========== Generar: 0 correctos, 1 incorrectos, 0 actualizados, 0 omitidos ==========
rajvardhan2 years ago
Congratulations on your project. It is indeed very inspiring.
Can you please explain me that in your techbitarFaceDetection.cpp file, what is exactly being done with the variables LSB and MSB. Further, what does the following line do:
LSB = faces[i].x & 0xff;
I see the wall of eyes from Dr. Who... and want to make one :)
techbitar (author)  stringstretcher2 years ago
GraffikeL2 years ago
Where is "Tserial.h"? i can't find it. It has errors
techbitar (author)  GraffikeL2 years ago
I have a link to it under tools. Search for:
sentryGun533 years ago
What would happen if you put a face on the camera itself.... then showed the camera a mirror?
You think like I do... We are not alone!
ArduArdu2 years ago
Any plans to update this for OpenCV 2.4.1?
techbitar (author)  ArduArdu2 years ago
I have plans to update this guide to make it simpler to follow. In the process I will refer to the latest version of OpenCV.
siddiqov3 years ago
Hi, i want to send x & y coordinates to arduino uno serially..i used the same code with correct com ports and baud rate but i couldn't send these values. i debugged my program and come to know that the "serial.available" value is 0. i am using visual studio express and the coding is in c++. i will appreciate for your feedback.
Roustan3 years ago
I am having problem communicating between c++ and the arduino board. I am getting Main.obj : error LNK2019: unresolved external symbol "public: void __cdecl Tserial::disconnect(void)" (?disconnect@Tserial@@QEAAXXZ) referenced in function main.
I can see that the problem is from the serial communication but i am not sure how to solve it. Any help will be appreciated.
1-40 of 61Next »
