Facebook Halloween Outfit
 by solidfunk
Featured
Step 2: Home now to build!
Build Build Build!!!
So I got home alive and only slightly came off the ground : P turning corners was the hardest part nearly hitting the edge on the ground. I now understand that it was silly and that I could have been pulled over try explaining the situation to the police officer.
"Very sorry officer I have this cardboard on my bike to make a face book outfit...."
OK back to business, I laid the cardboard down with the white side face down and using a small saw I cut the pieces of wood to the correct size. One problem I encountered was that the back of the cardboard was slightly well hairy? I don't know the best way to describe it but I knew that sticking would be difficult.
But I went ahead and done that anyway as I was running out of time it was already dark and I needed to be out soon!
I stuck the wood around the sides using no more nails that I had lying around. Notice that their is some hinges well I had an Idea that seeing as this was cut in half I could add a small flap to make this easier to get in a cab home when I am completely out of it and have probably lost the thing anyway. That didn't work because the hairy cardboard would not adhere properly!.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
