Introduction: Facilier's Talisman From the Princess and the Frog
Picture of Facilier's Talisman From the Princess and the Frog
Everyone needs a talisman.. EVERYONE
So why not set to making one.
This one was made within 4 hours and could have probably been made in less time if I had thought about what I was doing first and didn't stop for a delicious cup of tea.
Let me know what you think and I would love to see what you make.
Hopefully i will have made the mistakes so you don't have to.
Step 1: Scetch Out Facilier's Talisman
Picture of Scetch Out Facilier's Talisman
Luckily for this project there are some fantastic reference images available online.
Find reference material you like and make a sketch of half of the talisman on a folded peace of paper along the reflective center.
once you are happy push hard with your drawing implement to make a traceable indentation of the half you have drawn and then draw over this indentation.
If all goes right you should have a decent enough plan.
(I don't know how i got it wrong but I did.. I made my initial sketch in accurate which made the later steps a little more difficult until I realized what had happened)
I'm sure you will check your work before going onto the next steps.. (If you can learn from other peoples mistakes then you don't have to make them yourself.. Its an awesome time saver)
Step 2: Trace Your Sketch Onto the Wood
Picture of Trace Your Sketch Onto the Wood
Cover the back of your sketch with graphite from your pencil.
(This is easier with a softer pencil . I was using HB which is fine for this job)
Tape the sketch graphite side down onto the wood you want to use for your talisman.
(I am using beech because it takes stain well, is not expense and carves like a dream.)
((Its probably worth mentioning I had a nice flat surface,, a ruff surface will not work as well for this process))
Trace your sketch by drawing over your original sketch, this will leave a copy of your sketch on the wood.
Because I know sometimes a light colored pencil line can be difficult to see I went over the sketch on wood with a pen. (this isn't necessary but makes cutting out a little easier)
Step 3: Cutting Out and Diyeling in
Picture of Cutting Out and Diyeling in
I used a band saw to cut out the shape and refined this with a visit to my sanding station.
I suspect you could do this with a coping saw if you started with a more modest thickness of wood (and didn't have access to a band saw)
Step 4: Work Out How Thick You Want Your Talisman and Cut It to Width
Picture of Work Out How Thick You Want Your Talisman and Cut It to Width
Work out how thick you want your talisman and cut it to width.
This step can be avoided if you choose wood of a thickness sympathetic to your talisman or re saw your wood to an appropriate thickness before starting (I didn't not think ahead so had to clamp up and cut by hand)
Also I marked the thickness with a peace of paper and a pencil. The correct tool for this would be a marking gauge (I didn't have one handy and didn't need the accuracy so felt the folded paper method would satisfy.
Step 5: Tape, Tack and Clamp
Picture of Tape, Tack and Clamp
When carving its a great idea to be able to hold the peace your working on down.
I used double sided tape and 2 1" pins to hold the talisman in place on a scrap board before using some clamps to hold the whole thing to my desk.
Step 6: Start to Carve
Picture of Start to Carve
from looking at my reference materials I thought the talisman looked to fit a roughly upside down teardrop shape, near to the shape of niandatal axes (I have to confess I haven't watched the princess and the frog, Just some clips on you tube which looked ace)
With this idea I made the initial cuts shaping the more severe curve of the forehead and then tapering to the chin.
Step 7: Sand and Mark
Picture of Sand and Mark
I am lucky to have a nice little sanding tool .. sanding by hand takes more time.
When you have a smooth surface you can trace on the details of the talisman again.
Step 8: Carve the Details Referring to Your Reference Materials
Picture of Carve the Details Referring to Your Reference Materials
Carve the details referring to your reference materials.
Remember in stage one I told you I had sketched up wrong..
This is where I became aware of that.. When my reference material was different to my sketching .
Incidentally I switched from power to hand tools only for this stage. (I find it gives me a lot more control over the cuts)
My technique is to make a plunge cut from one direction and then work to this cut from the opposite direction (in a similar fashion to cutting blind dovetails with a chisel.
Step 9: Releece the Beast
Picture of Releece the Beast
Taking the pins out might be a bit of a headache.
I had to carve down a little before I could extract with pliers.
Braking the hold of the double sided tape when the pins are not in place is achieved by twisting the talisman.
Its a good idea to take off the remaining tape from the back of your talisman.
At this point Its nice to check the size and weight ect feel right.. If needed you can put it back on the board for more carving.
Step 10: Round Over the Edged
Picture of Round Over the Edged
Take a little time to round over edges and make sure everything is fine.
Its good practice to inspect your work constantly but building in extra inspection doubles this good practice. I also used sandpaper at this point.. I think the talisman should feel a bit rustic but I hate ruff edges.
Step 11: Color an Knock It Back
Picture of Color an Knock It Back
I think the talisman needed a rosewood stain, with its slight red tinge whilst still remaining nice and dark.
I painted on a coat of this stain before knocking it back with kitchen roll. This takes stain away from the highest areas whilst allowing the cracks to be un touched and remain dark.. I further highlighted by sanding some of the stain away from the highest areas.
Step 12: Put a Hole in Its Head
Picture of Put a Hole in Its Head
I used a drill press to create a threading hole, then took care to stain this hole. (again my order is a little off, ideally you should drill before begging staining)
Step 13: Add a Finish and Buff
Picture of Add a Finish and Buff
I used microcrystalin wax held back for a little while before buffing the talisman. I like this wax.
Step 14: Thread Your Talisman
Picture of Thread Your Talisman
I find it easier to tape something long and thin to my thread and push it through a hole than trying to push a non ridged string. here i,m using a cotton tip masking taped onto string as a tool.
Step 15: Tie a Not in the String and Unleash the Power of Voodoo
Picture of Tie a Not in the String and Unleash the Power of Voodoo
tie a not in the string and unleash the power of voodoo
Step 16:
gress175 (author)2015-06-12
I know this kinda defeats the purpose of this sight but I don't have the tools you do and my wife would love one of these if interested I would totally buy one from you
As luck would have it I still have the talisman. send me a message and I'm sure we can work something out. PS there is a place on the forums for people to sell what they have made, I think instructables are on board with people using it to trade. If you do buy I will include a blank incase you get some tools in the future.
Kyleluvspets (author)2015-04-28
So do you believe that a talisman actually helps you? I'm not trying to start a battle between beliefs, I am just wondering. Do you believe in God?
MissionSRX (author)2015-04-01
Congrats on the win! I concur it must have been a close one.
Thank you. Your Dragon Wing Celtic Knot Pendant looks very fine work, I love the design an choice of wood . I think any one could have easily won.
By the way. I love your Hot Rod Plane Restoration.https://www.instructables.com/id/Hot-Rod-Plane-Rest... I did a little restoration of an old Stanley plane a little while ago and found it really rewarding. https://www.facebook.com/226105337417684/photos/pb...
I played around with installing a Lie Nelson blade and found it improved the planes overall performance but didn't even think about changing the design of the handle.
Its a stroke of inspiration. I'm inspired to brake through a boundary I once had and go to town on the next restoration project that excites me. (There is something about a nice tool that gladdens the heart)
ashleyjlong (author)2015-04-01
ooh! I well deserved win --Congrats!
Hey, Thank you. I am extremely happy. Its an honer to make it to the selection stage with so many great instructables. I think it must have been very difficult to pick a winner. By the way- Me and my girlfriend have just bought our first pet tarantula (My first pet ever) and found your Terrarium Makeover really helpful. Here he is https://www.tumblr.com/blog/mrfancylegs
Then congrats on the new pet as well! Arachnids are one of the few things I've never owned, but I hope he/she will enjoy a swanky new home with some of those tips.
Absolutely. We bought him some new heating yesterday an he seems to be as snug as a bug in a terrarium. This is my first pet since I was 3 so I am learning a lot. I feel very responcable as all good pet owners should.
sir_ghattas (author)2015-03-30
This is great, I think i may have to make one of a dragon priest.
Hey thanks.
I have been thinking about high end cos-play for a little while. The dragon priest and death eaters are on mt list of to make masks but at the moment for a carved mask I have a real love of the idea of carving a mask of majora. (Saying this I have a wall with no art and I think a whole bunch of carvings and masks would look ace there) Thanks again
rathemighty (author)2015-03-23
You forgot to make it bite, but other than that, nice work! It's really quite magnificent!
That is an awesome idea. I think hiding a cigar cutter inside of it would make it a bit super cool. An thanks.
tomatoskins (author)2015-03-20
This is awesome! I love how it turned out!
Me to. Thanks buddy :D
Howto246 (author)2015-03-20
Cool ill have to try this
Awesome. I would love to see what you end up with. Word of advice I didn't put in the main body. carving is much easier and safer with sharp tools.
Also I would recommend joining a turning or carving club if you have one near by. Some times the members are a bit standoffish but other times they can be a mine of good advice and helpfulness.
NathanSellers (author)2015-03-20
This looks really cool. I like how you sanded down the stain on the high points. It really increases the rustic look. What a fun project.
Hi thank you, I did have a lot of fun.
I once had the opportunity to work with a furniture restorer. This method of knocking back the stain was used to artificially age the new work so it blended with the original work.
Recently I have created some WITCO recreations for a friend of mine who loves anything tiki. Part of there production method was to set fire to the wood. (this changes the color as well as knocks back any ruff high points) If you are going to set fire to your work I would recommend doing it before staining or finishing- I suspect otherwhise there might be some nasty things to suck into your lungs.
About This Instructable
9,077views
267favorites
License:
Bio: I work for a charity most of the time but when i,m not i am a wood tuner, former teacher, artist and prop maker ... More »
More by world of woodcraft:OUIJA and Heart Etched Pendants Erganomic Oblique Dip Pen conceptCarved wooden pumpkin box
Add instructable to:
