Fade Linkit One
81
Posted
Introduction: Fade Linkit One
This is a simple Fade feature of Linkit One . The led in it will glow to the fullest than it will dim after some time than again it will glow to the fullest than it will follow the same procedure .
Step 1: Parts
• Linkit One
• Linkit One USB cable
• LEDs
• Linkit One Battery
Step 2: Code
Upload this code
Fade
This example shows how to fade an LED on pin 9
using the analogWrite() function.
This example code is in the public domain.
int led = 9; // the pin that the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup() {
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(30);
Step 3: Finishing
Now you just need to remove the USB cable and attach Linkit one's battery to it .
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
