Failed - Mini Wind Turbine
177
5
Posted
Introduction: Failed - Mini Wind Turbine
I love building small wind turbines for educational and experimental purposes. Some of them work and some just don't.
I learn from both those work and from those don't work.
So I actually make use of all of them.
In this instructable I'll show you a small wind turbine that I've recently made but didn't produce enough voltage to light an LED even though the wind speed was fairly enough to make other turbine work better.
Wish you the best. And have fun ,Live free And Read Books on Amazon
Step 1: Components
Motor Small motor from an old CD-ROM drive Amazon US , Banggood , Amazon UK , Aliexpress
LED ( I used white and then I used red )
Quadcopter blades 8045L 8 x 4.5L Amazon US , Banggood , Amazon UK , Aliexpress
Metal Pipe
PET bottle
Thread
Step 2: Connect Parts Together
Cut the PET bottle to make a small piece from the top of the bottle. This piece will be used to fix the motor on the metal pipe.
Insert the motor inside the bottle top as shown in the image.
Connect the LED to the motor terminals.
Using the thread, fix the piece of PET bottle to the metal pipe.
Put the metal pipe in a clear open area where there is a high air flow rate.
Step 3: Testing and Failure
Testing the Mini Wind Turbine in the wind. I thought the turbine speed was enough to light the LED. I was wrong.
Although I've tested the motor to light the LED by turning it with hand, it really worked. But when I connected it to the blades, its speed was dramatically reduced.
The blades were heavy for the motor and they rotated at relatively low speed which caused the motor to output very small voltage.
This small voltage wasn't enough to light a white LED or a red LED.
I've learned from this one that not all rotors are compatible to all motors.
And that not all blades can be used as blades for wind turbines.
Those quadcopter blades were heavy and slowly driven the motor to low rotational speed.
But I am on my quest for making better and easier wind turbines for all people who are willing to make.
Thank you for reading my instructable..
Do you like audio books and want to learn something new on the Go ?
This instructable is brought to you by Audible, the famous Audio Books Platform. You can now listen to free Audio Books from Audible.
Listen to Free Audio Books on Audible US ...
Listen to Free Audio Books on Audible CA ...
Listen to Free Audio Books on Audible UK ...
Listen to Free Audio Books on Audible DE ...
Listen to Free Audio Books on Audible FR ...
That's all. Thank you for reading.
Here are some of my latest books on Amazon.
Learn By Making
Backyard Wind Turbines
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
