Step 2Making the "cake"
Next, push a cupcake paper into each of the wells of the muffin tin. You may want to weigh these down with metal washers...I didn't but it might have been a good idea.
Now you're ready to start spraying!
Open your can of expansion foam....and be warned: one can goes a LONG ways so have plenty of cupcake papers ready! It is also one-time use so be sure you have enough time.
Now, spray the foam into one cup at a time, filling it about halfway full. It will rise just like it does in the oven. The only way to do this right is trial and error...so make plans for a few funky-looking cupcakes. Be really careful if you are doing miniature cupcakes...they overflow fast!
Let each cupcake sit in its well for a few minutes, then you can take them out carefully and set them on your newspaper to finish curing while you make more cupcakes in your tin. When you are done, let the cupcakes cure and throw away your gloves (which will probably be really sticky and gooey by now)
comment
Add Comment
Add Comment
