3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fake EL Wire
Fake EL Wire
Because real EL wire is somewhat expensive, I decided to make my own. It does not use the same principles of true EL wire, but it gives a similar effect.
What You Need:
Airline tubing (appx $3 for two meters. Available at pet stores and Walmart)
Bright LED flashlights (keychain ones work well)
tape
water
Step 1Filling the tubes up
Cut the airline tubing so that it is less than a meter long. If you are going to light these up in broad daylight, make them shorter that 30 cm (one foot). If the tubes are too long, the light won't be even.
Run water into the tube until there are no bubbles. If you want, you can color the water to make the light a different color.
Once the tubes are full, jam one of the LED's on the flashlight into the bottom and one on the top. Make sure water doesn't come out.
7 comments
May 22, 2011. 10:43 AM_Scratch_ says:
At this point, you might as well just buy about 10 feet of fiber optic cable for like, 10$ or something. Cool 'ible though.
May 21, 2011. 12:51 PMElectricFeel says:
It looks like it's more of a fake fiber optic than fake el wire
Jan 27, 2011. 10:11 AMyashfau says:
you can use a highlighter's color to soak in the water and instead of a normal led, use a UV led. this should surely be brighter through out. and better looking too with the glowing effect xD
May 18, 2011. 5:14 PMdragonsniper says:
thats what im doing for an art project
:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P:P
May 4, 2011. 7:45 PMThe nerdling says:
you could put copper/aluminium tape over the led so it will hold it and will make only the tube light up
Dec 2, 2010. 12:54 PMToastslayer says:
It'll glow much brighter if you use salt water. The downside is that if it leaks, it's more likely to short out any electronics.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:ANDY!
i like ice-cream.
