Fake Virus!!!
Fake Virus!!!
Want to prank your friends and shutdown their computer? Look here to see how. NOTE:it just shuts down it doesn't kill memory, programs, ETC. this is my second instructable!!!
any tips for me? please comment. thanks!
Step 1Start
Start
Ok if you want to be as diabolical and evil as me, here is what you do. First, right click on your desktop and click new shortcut
264 comments
1-40 of 264next »
Dec 6, 2011. 6:21 AMimayet says:
does not work
Apr 30, 2008. 5:29 PMDs HaKa says:
i made it look like the real internet explorer icon and hid the actual real one!
Nov 29, 2011. 7:09 PMDs HaKa says:
a little delayed but all I did was make a fake one, rename it to "Internet Explorer", and put it where the actual IE icon used to be. I don't think a pic would help much...
Oct 12, 2011. 8:37 AMMertDemir says:
0t is vrey simple then. 0t is already on your computer in system 32. And it is an app like .exe
You can search by start button.
Apr 1, 2010. 8:36 AM07855 says:
If u type 'shutdown -a' in cmd it will close
Aug 26, 2011. 12:47 PMtried says:
how u dose send it to a friend
Aug 29, 2011. 6:45 AM07855 says:
mail, skype... etc.
Sep 7, 2011. 12:49 AMkree1 says:
can you explain it a bit how to send it?
Sep 7, 2011. 1:40 PM07855 says:
Use wetransfer.com and rename your file to something like homework, there you go :)
Jun 11, 2011. 11:43 PMfabsy333 says:
If you are running Windows 7 or Windows Vista, instead of the timer, it says what time you've done AND it says the message. For example for the Windows 7\Windows Vista people, it says: 20 seconds till shutdown. %message%. There is NO timer. It just says how much time you've puttin.
Sep 13, 2010. 2:38 PMblacklistspy says:
how does it works.????
Jun 2, 2010. 1:45 AMspiderfurby says:
Windows Vista :-( this is a good trick but it falls over if you try to send it via email. When you attach the the shortcut to your email for some dumb and stupid reason the email client also attaches the executable. Grrr. Of course this in turn is detectable via virus checker. The element of surprise is muted when you send attachments that are compressed.
By common sense the shortcut should be the only file that is sent. Try to send a shortcut to a directory of photo's and that is all you get a shortcut and no photo's as you would expect. But point the shortcut to an executable or batch file and the rotten  shortcut once attached wants to send the file as well - go figure. When it come to compression unless it is a self uncompressed file (usually with an executable extension)  the element of surprise is lost.
As I found out not everyone is a rocket scientists. The mood of the joke is destroyed when you get a telephone call asking how to unzip a file. Or how to rename a file.
With that in mind has anyone found a work around that will allow a shortcut to be sent with out having the executable being attached.
Apr 27, 2010. 5:00 AMknex_mepalm says:
 You harmed me, some guy set this to run and I lost my 4000 word essay which was due tomorrow, good thing I saved at 1500 words. GEEZ, I blame you. Now I can sue you since you have no disclamer. See you in Court.
Oct 22, 2007. 10:24 AMPerkie says:
when the virus file is on your desktop right click and and choose send to compressed file, make sure you name the main file like(RedSox ALCS Pics) and after it is compressed do the same name.....Have fun
May 30, 2008. 6:32 PMCartuner55 says:
no its a baseball team... supposed to make it so RedSox fans will open it
Jan 16, 2010. 12:45 PMbadboy2k9 says:
HAHAHAHHAH
Jul 16, 2007. 11:48 AMhq says:
how do you send a virus in a email? i have gmail and it wont let me!
SAME HERE
Jan 16, 2010. 12:29 PMbadboy2k9 says:
you cant even  send it man,please give me more info
Sep 12, 2009. 9:06 PMBenwolfe91 says:
That ways alright but i have one a thousand times better. open your notepad and copy and paste the following @echo off color 0f REM: This and the following commands won't be shown on the console. REM: Now the console's color is green text on black screen. Scary! echo Deleting Critical System Files... REM: Everything that starts with "echo" is printed at the screen. REM: It is _not_ really done! echo del *.* ping -n 4 127.0.0.1>nul REM: Unfortunately there is no command to stop the programm for a few seconds. REM: But this would be cool, because the user needs time to read the output and REM: it must look like the computer is working on the things we "echo"'d above. REM: So what the above command does is: Sending four "pings" at itself. REM: Each ping lasts one second. So it's the best way to wait for four seconds. REM: The output of ping is redirected to nowhere (>nul) so it isn't shown anywhere echo Deletion Successful ping -n 2 127.0.0.1>nul REM: You can set the number of pings by changing the number behind the "-n" echo: REM: "Echo:" makes an empty line. (Like a break) echo: echo Deleting Root Partition... ping -n 2 127.0.0.1>nul echo del %SYSTEMROOT% ping -n 4 127.0.0.1>nul echo Deletion Successful ping -n 2 127.0.0.1>nul echo: echo: echo WARNING: Trojan File download Started echo cd C:\Documents and Settings\All Users\Start Menu\Programs\ ping -n 1 127.0.0.1>nul echo mkdir h4x ping -n 3 127.0.0.1>nul echo Trojan virus "juggarnaut" download complete echo: echo: echo Windows Vista ROM: /deleted ping -n 3 127.0.0.1>nul echo start hax.exe ping -n 3 127.0.0.1>nul echo SYNtax ERROR: all files corrupt echo: echo: ping -n 2 127.0.0.1>nul echo Disabling Windows Firewall... ping -n 2 127.0.0.1>nul echo Total system MALfunction ping -n 2 127.0.0.1>nul echo Allowing virus to boot from startup... ping -n 2 127.0.0.1>nul echo: echo: echo Deleting C: Hard drive/ documens / castlerp ping -n 2 127.0.0.1>nul shutdown -s -t 10 -c "FATAL ERROR: system malfunction in process." STOP: Dont copy this after you copy this in your notepad save it as fakevirus.bat dont forget the .bat, it turns it into a batch file. after this open your notepad again, click file, and the open, remember to open (all files) and find the fake virus you made, it will have a picture of gears on it, right click it and send it to your desktop. Once it is on your desktop right click it and click properties, then in the (combatibility) tab, check (run in 256 colors) and check (run in 640x480). this will give it the effect that your desktop is messing up, eventhough this is harmless. your computer will log off and shutdown like the one your explaining, but mine will give messages that a virus is deleting their whole harddrive. you can then change its icon and trick your friends even better. hope you like it!
Sep 3, 2009. 3:45 PMiKIA says:
it works. a friend did it in our computer class
Aug 27, 2009. 1:14 AMKhazza says:
Does this really work?? Or is this a scam for our PC's
Aug 7, 2009. 4:43 AMRadobot says:
Does anybody know how it works?
If no, then I have a account:
So, in every windows is a program that can shutdown, reboot computer or log you off.
To shotdown (or reboot...) computer windows is using this program.
And with that shortcut you are telling that program to shutdown.
P.S. If you use instead -s (like shutdown) -r computer will reboot (or -l to log you off).
Aug 7, 2009. 4:47 AMRadobot says:
That program is in: C:\Windows\System32\shutdown.exe
Jun 27, 2009. 3:47 PMli789 says:
I put the fake virus in an sd card. it still works
Jun 8, 2008. 3:28 PMpuffyfluff says:
Do you know about Print Screen? It takes a picture of your screen, and you don't need a camera. Just press print screen on your keyboard. The go into a program like Word or Publisher. Then paste.
Jun 18, 2009. 4:40 PMmax53389 says:
It would of been easier to use prt scrn button
Nov 9, 2008. 5:19 PMpuffyfluff says:
Oh. I see.
Not really...
Jun 7, 2009. 12:46 PMdanman17 says:
ughhh! it works on my computer but i cant find the cd- drive so i dont know how to send it to other people. someone please help me with this....
Mar 18, 2007. 9:15 PMjrgcool35 says:
DO NOT DO THIS!!! or do it at your own risk. I really messed up my friends computer with this. Dont try to sedn this to people or that same thing will happen -.-
Mar 15, 2009. 3:12 PMiBurn says:
Then you did something wrong. All it does is turn off your computer...
May 27, 2008. 9:42 AMMODX says:
No jrgcool35, this is a simple batch command executed through a shortcut rather than a batch file. If you save this in a notepad as a something.bat document and then run it, it will do the same thing, but will be more effective:
@echo off
shutdown -s -t 25 -c "you have been hacked"
set /p q=You have been hacked loser!
nice little kitty script. -.-
Nov 22, 2007. 12:13 PMSSuperSSoldier says:
u did wut? how, all this does is hsutdown your computer, did u mistype?
Oct 22, 2007. 4:10 AMgilros says:
Thanks
Mar 31, 2007. 5:22 AMbinnie says:
haha this is nothing u will not screw up any computer doing this get a life and stop being so dramatical
May 26, 2007. 4:05 PMjrgcool35 says:
Very nice of you to say......................Are you holding a badge in that picture or something?
1-40 of 264next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:kneecaps
