The fakenflicker is a tiny, battery powered candle simulator. 3 colored LED's authentically flicker and fade, just like a real candle, controlled by a PICaxe 08M.
This project was designed by propellanttech. You can get the kit or bare pcb from Gadget Gangster and download a PDF version of this howto. If you get the kit, the PICaxe will come pre-programmed, but the board has a programming cable connector if you'd like to reprogram it.
Here's a little video of the candle in action:
Warm up your soldering iron and get started!
Remove these ads by
Signing UpStep 1Parts List
- Fakenflicker PCB
- 3xAA Battery Box
- PICaxe 08M and 8 Pin dip socket
- 3x 120 ohm Resistors (Brown - Red - Brown)
- 1x 10k ohm Resistor (Brown - Black - Orange)
- 1x 22k ohm Resistor (Red - Red - Orange)
- 2x .1 uF ceramic capacitors
- 3x colored LCD's
- Optional - 3.5mm headphone jack to program the PICaxe
This looks interesting.
L
It's a fairly good effect - not perfect, but pretty good. One cool thing about the board, though, is that the headphone jack is right there if you want to reprogram or modify the software. And the sourcecode and board design are on the project page.
