3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fakin' It - Polaroid Transfers That Look Real
Fakin\
Some of you may or may not know what Polaroid transfers are. Those that have done actual transfers may scream blasphemy! while those who haven't may rejoice in finding a decent tutorial on how to replicate the effect.
Real Polaroid transfers provide a very unique effect, most notably around the edges of the photo. As Polaroid film stock either disappears or stops being produced entirely methods like this will be the only way to duplicate the effect.
I was recently working on a shoot where the editing was leading me down a path that made the photo look a little "grungy" and I thought a polaroid border would suit it well. I knew at one time there was some nice soul who had posted up a psd template that was an actual scan of a blank polaroid transfer so I started looking. After 2hrs and many stock photo sites that were selling exactly what I was looking for I decided what kind of photographer/graphic designer/photoshop fiend would I be if I simply purchased this file. Luckily I stumbed across a post that mentioned using ink and some watercolour paper, that's all I needed to read and I was off to find the box with my drawing stuff.
This process is quite simple, there are probably a multitude of ways to do this and I encourage you to tailor this process to your own style.
Materials
  • 1 or more sheets of watercolour paper - others may work but watercolour paper has a nice texture
  • Ink of some sort. I used fountain pen ink but you could probably use all sorts of other stuff like food colouring or maybe even fabric dye just make sure it is dark. Get creative. It doesn't have to be black, we can fix that in photoshop.
  • 1 or more popsicle sticks - again other stuff could work, just get someting with a flat edge that you can use to transfer the ink.
  • Scanner - If you don't have one see if you can scan documents to file using the copier at work. If all else fails I don't think Office Depot or Staples charge that much for this service.
  • Image editing software that supports layers. Photoshop is preferred but GIMP (which is free) will work too. This tutorial however will be citing photoshop tools/commands only.
Step 1Prepare your work surface
Prepare your work surface. Lay down some newspaper so you don't get ink on your table. It may also be a good idea to wear some old clothes just in case you splatter yourself.
26 comments
Oct 14, 2011. 3:54 AMwmcewen says:
Instead of pasting the photo into the layer, use the Place command under the File menu. This insets the inserted image, giving you handles (as in Free-Transform) allowing you to scale that image. It also puts that image on a separate layer, and makes it a Smart Object. Use the Save As command and keep a copy as a PSD. When reopening the file to use another background image, select the layer the background image is on, go to Layer > Smart Object > Replace and then choose a new file to insert into the old space. Use the Save As menu to do this over and over.
*IF* you want to erase part of the new background image (to trim it to fit) you will need to rasterize it first (its a Smart Object, and therefore unable to be erased as such) by going to Layer > Smart Object > Rasterize
Oct 22, 2009. 7:47 AMbrain_bomb says:
 So on a side note, Polaroid has just announced that they will start making the instant film again.  So if you missed your chance to do this for real you should have another shot starting in 2010.
Feb 6, 2011. 7:03 PMDumchicken says:
its 2011
Apr 19, 2010. 11:33 AMbeversmci2 says:
I am so pleased to read that Polaroid will make the film again. I am looking for #669. Any more info and dates about all of this ? Thanx.
Oct 25, 2009. 12:44 PMHardCoreHacker says:
uh yeah its canadian lol
Oct 25, 2009. 2:16 PMHardCoreHacker says:
I've eaten Old Dutch beefore though I could have sworn. (I was in America when I ate it.
Oct 27, 2009. 10:44 AMTofu says:
 Old Dutch is sold extensively in Wisconsin.  Can't speak for other states though.  :)
Apr 12, 2010. 5:47 PMmdawg22 says:
lol ur hawt
Oct 27, 2009. 10:54 AMTofu says:
 I am, admittedly, not familiar with Polaroid transfer techniques.  I had to read up on Wikipedia to see what they are.  Seem to me that it's a method of transferring the image from the physical film to another media (i.e. paper, textiles, ceramics, etc.)?
If so, and again please forgive my ignorance, is this what you do with the end product in this ible?
Also, couldn't a Photoshop brush be created that could create the border effect digitally (thus saving a few steps)?  Again I'm a newb at photography and Photoshop but it's a growing interest of mine.
Oct 27, 2009. 3:13 PMTofu says:
Thank you so much for the clarification!  Makes much more sense now.  Especially the reasoning for manually creating the border.  I can now understand why a grunge brush wouldn't work.  :)
Another question I have is whether or not you've ever used images, created via this technique, for printing on physical items (i.e. CafePress type output) or other formats (like printing to ceramic tiles for mosaics or similar)?  Just a curiosity question to know how they turned out in the end.  ;)
I should clarify that I'm a newb to photography.  For Photoshop I'm somewhere in the grey area between beginner and upper-level intermediate.  LOL  I frequent a Photoshop Contest forum and have a couple 2nd and 3rd place finishes.  I'm learning all the time!  :D
Thanks again for the clarification and info!  It's a great tip and technique!
Oct 28, 2009. 6:27 AMTofu says:
 HA!  I know that chop!  Joe did that!  I've been a member at PSC since October 2003.  :)
You wouldn't happen to be a PSC alum would you?  ;)
Oct 22, 2009. 5:23 AMphotographworks says:
No scanner? Photograph the image with your digital camera and use that.
I make various backgrounds and I find that photographing them with my digital camera gives as good results as scanning.
I'd be interested to hear your thoughts on that.
Oct 22, 2009. 7:07 AMkevio says:
Any decent scanner will have far more detail than a digital photo of something this textured. Most DSLRs use a Bayer sensor (the exception being the Foveon  sensor used by Sigma). Bayer sensors tend to blur fine detail. Photographing might be OK if you are doing it for fun or small prints. But pros will want to scan in order to get every detail.
Oct 22, 2009. 5:48 AMmowie says:
was your model in a microsoft 7 ad?
Oct 22, 2009. 5:20 AMsarahfish says:
 nice job, also thanks for the download, love the open source spirit! sweet!
Oct 21, 2009. 5:06 PMChromatica says:
who is that
not you right
Sep 21, 2009. 6:01 AMiectyx3c says:
Nice work, but is anyone else seeing big blue rectangles with PS in white type in place of some images? They seem to be files named yada-yada.svg.png My browser (Firefox latest.x) usually works fine with .png so maybe something else is up?
Oct 20, 2009. 3:22 PMZergling_pack says:
 Yeah i was seeing the same thing i was thinking that it errored loading so i refreshed and it stayed the same so i figured it was just like that.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
47
Author:jphphotography
Those who know me know that I've always got some project on the go at all times. My interests are varied enough that I can jump from one to the next and not get bored. I seem to learn by doing and the...
more »
