Falafel - Vegan Middle Eastern Food
2,692
108
6
Posted
Introduction: Falafel - Vegan Middle Eastern Food
Falafel is a popular Middle Eastern vegetarian dish. Falafel is traditionally served in pita pocket bread, with tahini sauce, hummus and fresh vegetable salad.
Step 1: Soak the Chickpeas
Wash 500 grams of chickpeas. Pour into a bowl and cover by 5 cm of cold water. Soak the chickpeas (garbanzo beans) overnight. After 8-12 hours, drain and rinse the chickpeas well.
Step 2: Grind
Pass the chickpeas through a meat grinder. Pass half a bunch of parsley, a small onion of about 100 grams and one garlic clove.
Step 3: Season
Add 1.5 teaspoons of salt, 1.5 teaspoons of ground cumin, 1 teaspoon of ground coriander, 0.5 teaspoon of baking powder, a teaspoon of baking soda, and 25 grams of bread crumbs. Mix everything well.
Step 4: Make Balls
Fill a deep, thick bottomed pan with about 1 liter of vegetable oil. Heat the oil to about 170 - 180 ° C (340 ° F).
While the oil heats, make the falafel balls. Use a special falafel scoop if you have it, or form walnut sized balls using your hands.
Step 5: Fry
Fry in batches until golden brown. The outside should be brown and crispy, while the inside should be fluffy and green. Remove from the hot oil, and place on paper towel lined plates to soak the extra oil. Serve hot!
Step 6: Enjoy!
Falafel is usually served inside pita bread, with fresh chopped vegetable salad, tahini sauce and hummus. You’ll find pita bread,tahini sauce and hummus recipes on our website www.videoculinary.com
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    Finally, the first falafel recipe I used and the falafels I made are perfectly cooked!
    This looks great. I'll be trying it very soon!
    I'm Jordanian and I approve this method :P , and the sandwiche recipe is perfect, except you are missing the ingredient that can make it or break it.. "el tatbeeleh" . a sauce made by mashing garlic, squeezing lemon or lime and dicing green peper. also tursu "cucumber pickles" can be added to the sandwich
    Do you have to soak canned chickpeas?
