Fall Detection of Old Man Using Cayenne
3,351
58
Posted in TechnologyMicrocontrollers
Introduction: Fall Detection of Old Man Using Cayenne
Falling down is too risky to many old man. If they are fall, we must helping them as soon as possible before any bad bad things happened. The problem is we can't always keep watch their activities.
So, in this project we will create a prototype of fall detection to solve the problem above.
This device should send an alert to your email if fall detected.
Step 1: Hardware and Software Required
Hardware needed :
NodeMCU ESP8266
MPU6050 triple axis acc gyro
Software needed :
Arduino IDE
MPU6050 library
Cayenne
Step 2: Circuit
Connect your NodeMCU to MPU6050 like the picture of circuit.
You can change your NodeMCU with ESP8266-12 (smaller than NodeMCU).
My plan is change NodeMCU with ESP8266 and add Li-Po battery with charger.
Trying to learn about ESP8266 deep sleep to preserve the battery capacity, so if no fall detection the ESP will entering deep sleep mode, and if fall detected it will connect to wifi and send an alert to mail.
Step 3: Programming NodeMCU
Import MPU6050 from github link provided before
Fill your cayenne token, ssid, and wifi password to the code.
Upload falldetection code to your NodeMCU
FallDetection
Step 4: Setting Up Your Cayenne Dashboard
Setup your cayenne dashboard, add a custom widget, choose two state widget and give it name, choose virtual pin V8 for connectivity, and press add widget.
Now press the trigger, give trigger's name, on if add the widget added befor, on then fill email with your email, and press save.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    2 Comments
    It's not working.
    Same error for me
    "Could not find a valid MPU6050 sensor, check wiring!"
    I followed your tutorial and when i open serial monitior it shows
