Fallout 4 How to Trap a Deathclaw
Published
Introduction: Fallout 4 How to Trap a Deathclaw
This is a step by step walk through on how to capture your very own Deathclaw in Fallout 4. I hope you all enjoy this and find it useful.
Step 1: Wasteland Workshop
You must have the Wasteland Workshop DLC to be able to accomplish this. The DLC is priced at $4.99 USD. If you do not have this and/or want to buy it, then you have come to the wrong place.
Step 2: Picking a Settlement
You can only build cages in a settlement that you control/help out. My choice settlement was the first on you go to, Sanctuary Hills. There are some ideal spots where you can put the cage. You can clear up some destroyed houses and put some cages down on the foundation.
Step 3: Meeting the Skill Requirements
The cages themselves will take some materials that will be explained in the next slide. This slide is all about what it will take to make the Deathclaw docile. You will need to build a Beta Wave Emitter to make the Deathclaw docile, which will take 2 skills. You will need at least 1 rank of Animal Friend and at least 1 rank of Wasteland Whisperer. Then and only then will you be able to build the Beta Wave Emitter.
Step 4: Materials
You will need some specific materials to make this cage. Here is the list of materials:
16 Steel
4 Copper
4 Gears
And 4 Yao Guai Meat
Once you have those materials, you will be able to place it down wherever it will fit in your settlement. For the Beta Wave Emitter, you will need the following:
5 Copper
8 Aluminum
4 Crystals
3 Circuitry
5 Nuclear Material
And 2 Rubber
Once you have that, you can place the Emitter down.
Step 5: The Generator
Now once you have all of those materials, you can now build the cage and the emitter. You will need to build a generator to power the emitter and the cage. To build the generator, you will need:
2 Gears
4 Steel
2 Rubber
2 Copper
And 1 Ceramic
Now you will be able build the generator. You will have to connect the generator to the emitter and the cage.
Step 6: The Cage
Now, with all of that stuff out of the way, you can now catch a Deathclaw. It will take some time, you can either sleep or one will wander in while you are away doing whatever you do in the Commonwealth. Once you catch one, you will need to put more bait in. To do that, you need to go into the workshop, highlight the cage, and use the repair option. Once you re-bait the trap, you will be good until you need to repair it again.
Step 7: Deathclaw
Now that you have a Deathclaw, TIME TO HAVE SOME FUN! You can built an arena and pit it against other mutated animals/insects, or humans/mutants. Or you can have it as your little pet.
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    • Creative Misuse Contest
    2 Discussions
    I'm a big fallout fan (and I already knew this)but great tutorial :D
    Thank you very much! I also am a big fan of Fallout, and I really appreciate the feedback!
