Fan Cooling System for a Guitar Tube Amplifier by ampRiser
This Instructable will show you how to make a
fan cooling system for your guitar/bass tube amplifier.
*This instructable requires electrical/electronics/woodworking tools and knowledge.*
***DO NOT MAKE THIS INSTRUCTABLE UNLESS YOU COMPLETELY UNDERSTAND
     ELECTRICAL POWER AND TUBE AMPLIFICATION***
If you can't or don't want to make one for your self,
I soon will have them available at...
www.ampRiser.com
Step 1: Fan Cooling System (pics of on/off temperatures)
This is a Fan Cooling System for a guitar/bass tube amplifier.
The Idea behind this instructable is that  tube amplifiers get very HOT!
I understand that Hot tubes=Great tone!!
Although heat can kill an amplifier.
If your power transformer gets to hot, it will cost about $100 to replace,
heat will kill your capacitors in the amplifier killing your tone, and be costly to repair,
If the temp gets to hot inside the cabinet you speaker could blow, it will cost $50 or more!
So this system can keep your amp cool and save you money!!!
I have ran many tests with this system on many different amplifiers,
on average a power transformer gets to 120deg. or more,
with My fan cooling system the temp drops to about 70deg.
lemonie says: Apr 10, 2010. 4:04 AM
That's a really nice job, two questions:
Could you fit the fan on the inside?
Are these things then badly designed in the first place, or just "cheap"?
L
ampRiser (author) says: Apr 10, 2010. 6:02 AM
Thanks!
I would NOT install the fan inside the chassis,
there is way to much power in there to mess around!
To say amps are badly designed? I say Yes and No,
Tube amp circuits get Hot it is a fact,
amp manufactures suggest placing a fan on your amp to keep it cool?
I have had power trans, caps, and other parts burn up because of heat.
With the fan cooling the trans, and circulating air in the cabinet,
I have Not had a problem in years!
lemonie says: Apr 10, 2010. 2:33 PM
Fitting the fan inside was a space consideration, I don't quite get the "there is way to much power in there to mess around!".
Do tube-amps sometimes come with fans, is yours one that just didn't?
L
ampRiser (author) says: Apr 10, 2010. 9:30 PM
The Fan Only extends about a 1/2",
for this instructable and liability reasons I kept it low voltage, and
isolated from the chassis and High Voltage circuitry.
The fan is cooling the power trans. (120v) that feeds 450v caps.
There is No tube combo amplifier with a built in fan?
Rack power amps have them built in like a computer does.
Nothing like this is available.
Patent Pend.
thanks again!
nownvr says: May 10, 2010. 9:14 PM
peavey classic 50 is on the inside just to say
ampRiser (author) says: May 13, 2010. 6:29 AM
Yes you are correct, the peavey classic 50 has a cooling fan built in,
this was designed for the application and is UL tested and listed.
Thanks I knew if something like this was already out there the experts
here at instructables would find it and let me know?
calgarc says: Dec 4, 2012. 1:03 AM
could you not put the electronics of the fan in a plastic case inside the cab, thus allowing you to store the fan inside
lemonie says: Apr 11, 2010. 12:52 AM
Right, that makes things clearer, thanks.
L
XOIIO says: Apr 10, 2010. 11:06 PM
Umm, I doubt anyone can completely know about electricity and guitar tube amplification, I think a basic understanding would be good enough.
ampRiser (author) says: Apr 11, 2010. 4:50 AM
I did Not mean completely, my point is if you don't understand electricity
within a tube amplifier, DON"T attempt to make this instructable!
I see a lot of crazy people on here when it comes to electricity?
Just a basic understanding of electricity is what gets people killed!!
XOIIO says: Apr 11, 2010. 5:28 AM
True, True LOL
I'm just a stickler sometimes.
gmoon says: Apr 10, 2010. 4:48 AM
Great! Top marks here.
I'm rebuilding an old Kalamazoo Bass 30, and using it a lot for guitar. But it's very poorly ventilated. So I've been planing on adding the fan.
My only concern is something you don't mention--noise. How did you choose the fan, and did you test different fans? Were there any noise issues after the installation?
ampRiser (author) says: Apr 10, 2010. 5:51 AM
Thank you very much!
Because it is Battery operated there is NO Noise?
I have made a few with different types of fans, there all about the same?
The only time there was any noise is when you use a poor quality
wall transformer to power the fan.
gmoon says: Apr 10, 2010. 5:45 AM
Ah, now I notice it's battery operated, so at least it's electrically isolated. Still, RPMs would cycle in the audible range, I should think.
No problems, though?
I'd want something that would run off the same mains connection.
ampRiser (author) says: Apr 10, 2010. 5:55 AM
I  have never wired one into the mains,
I know it can be done though, filter caps might block noise?
My personal amplifier I hard wire the amp to an outlet plug,
installed inside the cabinet for pedal power packs,
and have Not had any issues with noise?
gmoon says: Apr 10, 2010. 7:17 AM
Cool, thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
