I have tried toner transfer method ,Press N peel paper and photopaper. Result ?
None of these gave me nice results. Because these methods are only good if you are doing a single-sided boards.
When you are making the double sided boards, ironing causes toner to melt and this makes the papers slip a bit. BUT if you are working with 10th traces ther shouldn't be any slips.
With UV photoresist method (photolithographic) which is also used in production of silicon chips http://pcplus.techradar.com/node/3059 the results are near perfect.
Remove these ads by
Signing UpStep 1Equipments and stuff
---1 can of POSITIV-20 spray http://uk.farnell.com/kontakt-chemie/positiv-20-200ml/positive-resist-positiv-20-200ml/dp/80101 0 --nearly 20TL(Turkish liras in Turkey)
---or if you have access to sensitized PCB dont' bother to buy a Photoresist spray, pre made pcbs are way better but In Turkey there isn't any so i used spray.
--- Hair dryer to dry your positiv 20 sprayed pcbs
For Exposing PCB's
---1X Pair of glass at any size you like --Free
---2x 8watts of UV fluorescent lamps( I don't know the exact type uva-A or uva-b but these blacklight tubes are fine) ---3TL each
---2x Fluorescent modules which you can use it directly with fluorescent lamps --6TL each
---Heavy books wtih more than 400 pages and hard cover, dostoyevski is a good choice for this job :D
For Developing and Etching:
--- 1X Sink Cleaner in granulated form, infact it is just NaOH (Sodium Hydroxite) 0.5TL
--- 1X 1 liter Hydrogen Peroxide 7TL
--- 1X 1 liter Bleacher (hydrochloric acid) 1TL
Total cost: 46.5 TL equals to 31$
8
comments
Add Comment
Add Comment
