Introduction: Fantastic Festool Fence Fix
This fix is actually a little upgrade – necessitated by a knob stripping out. Ever since I bought this saw (around 2000/2001) I’ve been irritated with a few minor design issues. In general it’s a fantastic piece of equipment, but it could be better. As time goes by, I’ll be replacing most of the knobs on this fence with bicycle style cam-lock quick-releases.
This fix involves replacing the set knob on the saw-fence with a camlock/quick-release locking system from a bicycle. This is to replace the original steel bolt/brass and plastic knob combo. I understand the need to have brass on steel locking, and I can also say that replacing the original knob with a new Festool knob is not expensive, but my fix makes this a little better and easier to work with.
Problem:
Brass in plastic knob stripped out after years of loosening and tightening (and over-tightening). The actual strip occurred on a day when it was suddenly a lot colder than the previous day, so who knows, the temperature difference may have had some influence on the whole process.
Step 1:
Remove the stripped brass and plastic knob, bolt, and the aluminium spacer (little piece of pipe that prevents over tightening and damage to the lock-tab.)
Step 2:
Insert the quick release skewer and mark the point where this should be cut – be generous – it’s easier to trim it again if it was cut too long.
Step 3:
Cut new thread on the skewer.
Step 4:
Insert the skewer, nut and aluminium spacer and tighten the nut while “feeling” the cam-lock to determine the ideal pressure.
Job done! Enjoy how quickly you can now set your fence!
Workshop Contest
