****Edit****
I've added some pictures of the final product, which do it a lot more justice than what I have had here before.
***************DISCLAIMER*************************
THIS IS NOT REAL ARMOUR. THIS WONT STOP BULLETS/SWORDS/KNIFES/'ARROWS. If you're lucky it'll take the edge off a punch, and it's probably good against finger nail scratches, and will probably do pretty good against airsoft bbs. But this is no good for SCA heavy combat, or having a jousting tournament on motor cycles with your friends. That being said, it'll make a sweet Halloween costume!
The scope of this instructible will include the following:
I've been slowly growing this instructable as I complete different parts of the suit, and I may have missed some spots. So if you see something like "3 steps to go" when really there's 6 or 7 that's why.
Making a vest to support your plates
Making the templates for your plates
Cutting your plates
Hammering your plates
Attaching your plates to the Vest
Making sure you can actually put on the vest
I am building a suit of armor for this Halloween. As it is a fairly intense process, I have started way in advance. If you are planning on mimicking this for Halloween this year, I would suggest that you start now. This instructable will focus on the plate mail that "protects" the torso. As this will be made using 30ga galvanized steel, it wont be any good as actual armor, but it should have the desired look.
This armor is a relatively long undertaking and requires a decent selection of tools. This might be do-able by 2 or 3 people in a week-end if they spend the entire week-end working on it in a team, a lot of it is repetition and can be somewhat assembly lined.
ex: one person cuts templates, one person safes the edges, and a third sticks it on.
Through out this project I will try to parallel the actual instructions with quick and dirty DIY, (QDD) style instructions, for those who want a fast project that's easier, faster but wont look as nice, and wont last as long.
Remove these ads by
Signing UpStep 1Materials
Non- Consumables, all of these are available at almost any hardware store.
*Tin snips ( Usually sold in packs of 3 for right straight and left turns/ cuts)
*Hand riveter
*Drill
*Hammer (ball-peen hammer preferred but not 100% necessary)
*Work gloves
*Marker or pen ( Something to mark steel & poster board)
*Scissors
*A long ruler ( But you can use one of the sheets of steel instead)
*A work bench or surface that can get seriously damaged (I used an old stool that was being thrown out )
*An Anvil ( If you've got one it'd help, I used the head of a sledge hammer because it was cheap, but if you own an anvil chances are you don't need this Instructable)
*Sewing Machine ( or just a needle if you've got time and no sewing machine)
Consumables
*30ga galvanized steel By then end I'd used about 10 ducting joists. Pop cans wont fly on this one because you're going to need large continuous pieces.
*Rivets - I used pop rivets in my project, because they're easy to find, easy to use and work very well. If you want, you can use peening rivets in the exact same way.
*Heavy canvas / denim + thread for sewing
*Poster board
13
comments
Add Comment
Deathcapt (author)
says:
karossii
says:
Deathcapt (author)
says:
armourkris
says:
armourkris
says:
Deathcapt (author)
says:
Add Comment
