Introduction: Fantasy Map Coasters
Picture of Fantasy Map Coasters
Whether you are in an epic campaign against a goblin horde, marathoning Frodo wandering Middle-earth, or deep into the saga with a coming winter this is a perfect place to rest your drink while keeping you immersed in the adventure.
This is totally open to customization, print out whatever you would like and you can put them on yours, and makes a great quick last minute gift.
Step 1: Materials
Picture of Materials
Things you will need for this project.
Map Sections: You could use a map or page out of an atlas that you already have. I opted to print out some sections of a map I liked. I cropped the sections to 4 in x 4 in squares.
Brushes: Any sort of brush will really do for this. It just needs to be able to evenly spread your Mod Podge.
Tile: I found some really nice looking tumbled marble tile at my local hardware store. Mine are 4in x 4in squares.
Scissors: You'll need something to cut and trim the map to the size of the tiles.
Mod Podge: This will bind the map to the tile as well as act as a sealer.
Other than this I would say you might want to lay down something on your work station.
Step 2: Prep Work
Picture of Prep Work
So the first step to this is doing a little prep work.
The tiles you are using probably have some dirt or dust on them from the shop. You can hit them up with some soap and water, compressed air, or just brush them off. Whatever your weapon of choice is, just make sure the surface of the tile is clean.
A clean surface is going to allow the Mod Podge or other glue that you use to get a better grip on the tile's surface. If not you run the risk of it peeling up or bubbles in the map.
Speaking of the map, go ahead and cut out your pieces. I went with 4x4 print outs, but that doesn't fully wrap around the edges. If you really want that full look go ahead and make them just slight larger then trim to fit to your liking.
Step 3: Weathering
Picture of Weathering
Weathering is going to make the maps pieces look like they lived a rugged life.
This step is completely optional but I think it works really well with natural and tumbled tiles.
Start off with balling up your map square into a little ball. Then undo that and make it flat again, evaluate how the character of the map is now. If you want more character, then ball or roll up it up again. You can also add a crease to it, use the the scissors to score it , or if you are daring rip and wear a few holes in it.
Not show: For another level of weathering, brush on some coffee or paint. Flicking or randomly splatter some across the surface. Dip a glass in your medium and press it on the surface for some well used rigs.
Be creative and mix it up.
Step 4: Time to Get Sticky
Picture of Time to Get Sticky
Crack open your Mod Podge, or glue of choice.
So lay your map face down, and evenly coat the back with a hearty amount of glue.
Next apply some to the surface of the tile. Then square up the map on the tile and lay the map on. You may need to add more glue to the tile as you apply.
It's okay to go heavy on the glue application, just make sure to even it out afterwards.
Step 5: Mind the Nooks and Crannies
Picture of Mind the Nooks and Crannies
You have to be gentle yet firm with this phase.
Once the map has been applied to the surface, gently attack it from every angle with the brush. This will allow the paper to take on the tile's surface, giving it character and ensuring a better binding of the two.
Not all section of this are going to want to lay down or contour to the surface of the tile. Additional glue will make the paper more pliable, and have a better seal to the tile. Just be careful, once saturated the paper is even more prone to ripping and being torn apart in ways you may not have intended.
The paper could flip over on itself and could stick together. When you try and removing it, tearing may occur. Just take things slow and easy.
Step 6: Build It Up
Picture of Build It Up
Once the first coat has fully dried, we can begin this. Applying multiple layers will strengthen the coaster and also cover the rough edges that may scratch or blemish a table top.
Start by adding an additional layer to the top. Once that has fully dried, flip it over and apply a coat to the bottom and sides. Then repeat the first step.
Do this two to three more times, it depends on how heavily you apply your coats. Having more thin coats works better than fewer thick coats.
Step 7: Final Thoughts
Picture of Final Thoughts
Well its all done!
If you want to take this to the next level you could get some acrylic sealer and spray on a few coats for additional protection.
Also if you don't feel entirely comfortable with encasing the tile, or want to save on materials look into felt, rubber, or cork self adhesive pads
If you had the time you could also have it that when you assemble the coasters they can make an actual map and be semi-functional in that aspect as well.
I hope you have fun if you decide you want to try this and enjoy.
Cliffsidegirl (author)2016-01-06
Cute! Can't wait to make some of my own
mchau2 (author)2016-01-03
What if you make piece that assemble s a bigger picture and hide it along with the easter egg hunt? I am excited
Draculorum (author)2015-12-30
Another idea would be to add some thin corkboard rounds to the bottom of the stones so they don't scratch wood surfaces.
joshua.artist (author)2015-12-29
A couple of hints. #1:Tea staining gives the most realistic aging for paper. (I like Earl Grey, It's strong and dark and tastes yummy, especially when mixed with a spiced Chi). #2: Isopropal alcohol, (rubbing alcohol 80% or better), is the best cleaner to help stuff stick. paint,stickers, decoupage, whatever...#3: A spray fixative on the image before you start putting wet junk all over it is a good idea too. It's like a matte acrylic spray artists use on pencil, pastels, charcoal, so they don't smear but then we can draw some more over them. Some printer inks do funky things when wet. I'm going to be using pictures of antique chinese art on tiles then tiling a table for my porch. Let your imagination soar!!!
Owl Trained ED Doc (author)2015-12-28
I have a handful of these coasters already made. Not sure how the decopage (sp?) will hold up, so I will try to do an image transfer instead with a poly overcoat. I'll let you know how it works. Great inspiration!!
VonRainbowpants (author)2015-12-28
I love how you weathered the maps! I've done projects like this before to preserve photos and wedding invitations, and I've found the best Mod Podge to use is Mattte. It's self-leveling so it doesn't leave brush strokes, and it dries without that "sticky" feeling.
RobinDean (author)2015-12-27
This is awesome! It’s easy to
think of many variations of this process (vintage Christmas coasters, family
photos, pictures from the garden…) and really gets my creative juices
flowing Thanks for sharing this, can’t
wait to do this!
Cindy Skillman (author)2015-12-26
I think PVA is water soluble, but you could use a clear carpenter's glue (diluted) or acrylic medium.
stechi (author)2015-12-26
What's a UK equivalent of Mod Podge? Is it PVA?
leonardots (author)2015-12-26
Skyrim map FTW!
leonardots (author)leonardots2015-12-26
btw, where did you download the map in high res?
I frond a copy that worked by using google image search, then with search tools set size to something like 4 MP or larger.
MetinE (author)2015-12-26
nice work Dovah
Viaticus (author)2015-12-26
Brilliant! I wish I had seen this a couple weeks ago - I could have made some as gifts! Thanks so much for sharing this - it's fantastic!
rc jedi (author)2015-12-25
Awesome! We can do other themes too.
Harvard82 (author)2015-12-25
love it
dan3008 (author)2015-12-25
I solemnly swear I am drinking no good ;)
emilyvanleemput (author)2015-12-25
Who doesn't love fantasy maps, right? They look great!
About This Instructable
11,857views
367favorites
License:
Bio: Just another nerdy creative type, who is making his way thru the verse.
More by MichaelRHerrera:Canon Macro Kit LensFantasy Map CoastersDIY IKEA Document Wall Holder
Add instructable to:
