Far Flying Paper Dart
Published
Introduction: Far Flying Paper Dart
In this instructable, I will show you how to make a paper dart that when thrown correctly can fly up to 75 to 100 yards. btw sorry for photo quality in advance
Step 1: Stuff Needed
2 pieces of printer paper
scissors
glue stick
some form of tape- optional
Step 2: Rolling Paper #1
from one corner of the paper, start rolling. Tighter is better. Yes, I just said that
once all rolled up and you only have a small flap left, apply some glue stick glue to the inside of the flap
roll up the rest and make sure its all glued down
you should now have a thin, slender tube that is fairly stiff
Step 3: Cutting Ends and Making Fins
Cut off both ends of the rolled up tube with scissors so they are square
Take paper #2 and fold it up accordion style two times
Draw out a design for your fins, make sure the narrow end is not wider than the diameter of the tube
cut out the fins so you have one singular fin and two connected ones
cut apart the connected ones so you have three individual fins
Step 4: Attaching Fins to Body
Pinch one end of the tube with three fingers so the tube has a cross-section of a triangle, do this for the entire length of where the fins will be glued
take your glue stick and generously apply glue to the entire tail section where the fins will be mounted
apply the fins one at a time so they are straight and line up with the top of each side of the triangular tube. press down on the fins so they are stuck down good
wait for a minute or two for the glue to dry
take some tape or glue covered paper strip and wrap the fins around at the narrow ends of the fins. Be careful on this step, if the glue is not fully dry or the fins were not attached enough in the previous step, they will slide out of place and will not align correctly
Step 5: Making a Nose Cone
This step is optional, but it will make the dart look mean and it will fly farther.
Cut out a smallish section of paper from paper #2 and roll it up so it forms a sharp cone type shape
Use the same method you used to glue the tube together to glue the nosecone together
(I used a small piece of electrical tape to hold it together, I find it works better)
put it on the tube on the end opposite of the fins to determine where you need to trim the nose cone
cut the nose cone to length
btw- i would make a couple of these because they tend to get bent upon landing
Step 6: Fitting the Nose Cone
Take the end opposite the fins and pinch in both sides of the tube so the nose cone will fit snugly on (should make a figure 8 type shaper)
Now you can either coat the nosecone end with glue and press the nose cone on with the glue, or you can press the nose cone on and use some tape wrapped around to keep the nose cone in place
Step 7: Finished Product and Throwing
Well there you have it
With a good huck, using the throwing method shown in picture 2, this dart fill fly for unimaginable distances, or you can use it for closer range attack and defense of a desk
Have Fun!
    • Planter Challenge
      Planter Challenge
    • Stick It! Contest
      Stick It! Contest
    • Clocks Contest
      Clocks Contest
    10 Comments
    this was damn cool, looks like it's effective if some cardboard parts are used then there's a diy practice arrow XD.
    Colo!!!!!!!!!!
    this is AMAZING. when I made my first one everyone else was just staring at it like 0_o so there were a bunch of people like
    (0_o) (0_o) (0_o) (0_o) (0_o) |
    oops it wasn't supposed to be like that
    btw how do you delete comments that you posted?
    i put a kebab stick i mine.
    reminds me of missiles with the nose as a warhead.
    Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i love makeing darts!!!!!!! darts ftw!!! lol but 4real nice work XD
    cool!
