3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Faraday For Fun: An Electronic Batteryless Dice
There has been a lot of interest in muscle powered electronic devices, due in large part to the success of Perpetual TorchPerpetual Torch, also known as battery-less LED torch. The battery-less torch consists of a voltage generator to power the LEDs, an electronic circuit to condition and store the voltage produced by the voltage generator and high efficiency white LEDs.
The muscle powered voltage generator is based on Faraday's law, consisting of a tube with cylindrical magnets. The tube is wound with a coil of magnet wire. As the tube is shaken, the magnets traverse the length of the tube back and forth, thus changing the magnetic flux through the coil and the coil therefore produces an AC voltage. We will come back to this later in the Instructable.
This Instructable shows you how to build an electronic, batterless dice. A photograph of the built unit is seen below.
But first some background --->
Step 1An Electronic Dice
An Electronic Dice
Instead of a traditional dice, it is nice and cool to use an electronic dice. Usually such a dice would consist of an electronic circuit and a LED display. The LED display could be a seven segment display that could display numbers between 1 and 6 as seen below or perhaps, to mimic the traditional dice pattern, it could consist of 7 LEDs arranged as shown in the second figure. Both the dice designs have a switch, which the user has to press when she/he wants to "roll the dice" (or "roll the die"?). The switch triggers a random number generator programmed in the microcontroller and the random number is then displayed on the seven segment display or the LED display. When the user wants a new number, the switch has to be pressed again.
55 comments
1-40 of 55next »
Mar 19, 2012. 4:41 PM50h9j says:
This sounds impressive, but I am worried that the 15V is measured on an oscilloscope with high impedance and the current is measured on a short circuit, i.e. very low impedance. This flatters both measurements and gives no indication of actual power produced, particularly not sustained or average power over the cycle.
I have been looking at student wavepower converters that use such devices and I can't help thinking they are very low efficiency. This is reinforced by not finding any commercially designed machines with Faraday linear generators, of whatever they are called.
I would be interested if you could estimate the mechanical power input to your device and the electrical power output and come up with an efficiency. One way would be to power the device from an electric motor and mechanism of known efficiency.
Oct 10, 2008. 12:32 PMshylock says:
I have batteryless dice, they are cube-shaped with dots on them. ; )
Oct 29, 2008. 4:41 AMstevenbelieven says:
cube batteryless dice?? i would pay respect to see
Sep 14, 2011. 12:58 PMstatic says:
Those are "analog" die. ;)
Oct 29, 2008. 6:10 AMstevenbelieven says:
led to this application hahahaha it was all about led AS THIS MY GAME ON A LARGE SCALE !!! IN ASIA PEACE STEVENBELIEVEN4NOW
Aug 26, 2011. 8:13 AMnanosec12 says:
Wow, just Wow....this is one of the best written instructibles I have ever read, and well documented with pictures as well. I love that you went into the history and theory, instead of just writing up a 'how to' Thanks
5 of 5 of course.
Nano
Jan 13, 2011. 12:30 PMnoaddict says:
Why don't you lock 2 magnets on the end of the tube and let the one in the middle to do the job? So you won't "crash" the magnets every time you roll.
Oct 7, 2010. 8:56 PMrevfnord says:
I would love to make one of these inside a magic 8 ball with blue LEDs!!!
Love the tutorial, great job!
Sep 3, 2010. 12:10 AMjornie says:
how much is this worth if i would buy all the stuff?
Aug 7, 2010. 4:06 PMknightowl says:
Awesome build. Going on my "to make" pile for sure. also, good luck getting that thing through airport security.
Jun 19, 2010. 5:30 PMsandman99 says:
what does it do
Dec 27, 2009. 8:11 AMgodofal says:
im olmost done!
but i forgot to order the pulse detector  diodes >.<
and i still  need to wrap the tube with that copper wire...
but i have the rest ready :)
Dec 31, 2009. 4:58 AMgodofal says:
well, i dont have a big lab :D
i have a 3 sorts of stuff lying around; resistors, capacitors, and LEDs
for the rest, i need to order everything if i need some specific thing...
Sep 21, 2008. 1:46 AMKidogo says:
is the uF important?
Dec 2, 2009. 3:06 PMAxaj says:
Yes, very important.  Sparkfun has a 10F (10,000,000 μF!) 2.5 volt capacitor for ~$5 (wire two in series for 5F, 5V).  I would highly recommend that.  But on a side note, I'd like to point out that dice is plural, while die is singular.
May 27, 2009. 5:01 PMIridium7 says:
do these things just pick any random number or something?
Apr 7, 2009. 6:36 PMmicroman171 says:
Nice work :-) I like the way you have sorted out the 2 dice version. Will you be rapidly changing between the two displays (POV making it seem as though two dice) or one at a time? If magnet wire wasn't so expensive and hard to find in New Zealand, I would try this for sure! Would most likely use a PICAXE instead as that is what I use. Keep it up mate!
Jan 10, 2009. 10:25 AMSparklesam says:
The project is really cool, but u call it a batteryless dice. Real dice don't have batteries. Its a really cool idea, but what's the point when you can just use real dice?
Mar 7, 2009. 9:26 AMwize says:
It's cooler. And it's electronic and batteryless. Its not just batteryless.
Feb 1, 2009. 8:58 AMfrenzone says:
-.- ... guess we'll call it batteryless electronic dice. as most of the things on this site the point is ... just doing it!
Dec 18, 2010. 4:43 AMEarths_hope says:
But no, a capacitor is a battery of sorts, so this is not batteryless
Sep 14, 2011. 1:29 PMstatic says:
Respectfully, I know it has become popular to erroneously to refer to a battery, when they are completely two different items. Popular doesn't equal "battery of sorts", so this project use no battery. Yes it's "batteryless"
Feb 1, 2009. 9:46 AMSparklesam says:
ur right. cool project gadre
Feb 18, 2009. 6:28 PMDIY Dave says:
cool
Feb 7, 2009. 7:00 PMcyborn95 says:
This project is awesome but things need to be more descriptive. When building the circuit, I see resistors but you just call the resistors a pulse detector. I would like to build it but building the circuit is just too complicated. Also, in the intro you should put a complete list of what we need to build it.
Oct 18, 2008. 10:03 PMAndruha1123 says:
hi, it seems as you know what you are doing. I'm pretty new to this and have a question. Can i use yellow wire instead of the red one(magnet)? And do i have to use rare earth magnets? i bought (N42, Dia 3/8"X1/8", Axially Magnetized. Ni+Cu+Ni plated.) these magnets, would they work at all???thanks, looking forward to your answer, really wanna make this.
Jan 17, 2009. 10:30 AMalexgeek says:
Where can this wire be bought? Does it have to be insulated or can it be bare metal wound around? Is this type of wire in any household equipment that i could rip apart and scavenge? Thanks :)
Jan 17, 2009. 7:18 PMalexgeek says:
Thanks! If not, do many places sell it relatively cheap? Not found many good sites that sell it. Cheers.
Jan 17, 2009. 8:12 PMAndruha1123 says:
RADIOSHACK
Jan 17, 2009. 7:39 PMAndruha1123 says:
I GOT MINE FROM AN OLD MONITOR. I FOUND THAT THIS IS THE BEST SOURCE.
Oct 18, 2008. 10:22 PMAndruha1123 says:
here is the website and the specific magnet i bough, i'm thinking this would help. i bought 4 of them.
http://www.magnet4sale.com/product.php?productid=16394&cat=357&page=1
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:Gadre
