Farmhouse Makeover for a Buffet/Console
544
5
Posted in WorkshopFurniture
Introduction: Farmhouse Makeover for a Buffet/Console
If you are someone whole loves farmhouse style decor, but don't want to buy new furniture, here's a way to give a farmhouse look to any type of buffet, console, or anything with cabinets.
Step 1: STEP 1: Take Inside of Doors Off
I had originally put mirrors in the doors, but both ended up breaking and I wanted something more sturdy for a house with kids.
Step 2: STEP 2: Add Harboard
If your furniture already had regular cupboards, you can skip this part. If it's not a flat surface and you want to replace the door, inspect your furniture and figure out how to remove the middle of the door. Some will just pop right out, others may need a saw.
I picked up some hardboard from Lowe's and had them cut it down to the sizes I needed. The boards start out as 4'x8' so you can get a lot of pieces out of it, so plan ahead for any projects you could use this for. A great way to use it is to make a chalkboard, which you can see a tutorial for here: http://www.finditfixitorbuildit.com/how-to-make-a...
To attach the hardboard, you can use mirror clips. Just drill a hole, then screw into place. I used 6 clips for each board.
Step 3: STEP 3: Use 1x2s to Make Xs on the Doors
Cut 1x2s to fit the diagonal. Sand and glue into place with Liquid Nails, Gorilla Glue, or anything similar.
Measure, cut and sand 2 more pieces to make an "X" shape.
For more details on this process, visit http://www.finditfixitorbuildit.com/how-to-paint-furniture-white-tv-console/
Step 4: STEP 4: Sand & Primer
Remove hardware and sand the entire thing. Apply 1-2 coats of primer, depending on how dark the furniture is. Use a paint brush to put paint on, then fell smooth with a 5" foam roller.
If you are using chalk paint, you can skip the sanding and priming. Here's an inexpensive and easy DIY chalk paint recipe to turn any paint into chalk paint: http://www.finditfixitorbuildit.com/easy-chalk-paint-recipe-tips-for-easier-clean-up/
Step 5: STEP 5: Paint
Apply 2-3 coats of paint using the paint brush and 5" foam roller. This color is "Creamy" by Sherwin Williams in satin.
Step 6: STEP 6: Protective Coat
You can either distress using sandpaper on the corners and edges or use 2-3 protective coats using the product of your choice. Because it's easy, I used Rust-oleum Stain Clean Enamel on this.
Reattach hardware. If you'd like some tips on easy ways to spray paint hardware click here: http://www.finditfixitorbuildit.com/upcycled-desk-with-hardware/
Step 7: STEP 7: Let Dry
Let cure for a few days before you put anything on top of it.
For a more detailed tutorial, please check out: http://www.finditfixitorbuildit.com/how-to-paint-furniture-white-tv-console/
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
