3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Faroun Lenz v2 Vertical Axis Wind Turbine
http://www.vawt.tk
keep in mind that this one is easier to build than my Savonius.
i kept it very basic.
to build the turbine, you need the following material:
-3 bicycle 29" wheels $5.00
-12 lamminate flooring $20.00 ( .25"x8"x4'.4") <----only for testing.
-Various sizes of screws $7.00
-3" PVC cut in 2 $50.00 or (cardboard tubing for start) <------only for testing
-wood or metal straping for the inside of rims to keep it from twisting apart. $10.00
- mider saw, band saw,...etc "$$alot of money for the tools$$"
THis Turbine is only to present a diffrent idea on how to build one of these turbines
-I have included 2 movies that shows it in cartboard and pvc tubing.
use proper material for builing it permenently.
science & tech , wind, turbine, generator, science, experiment, renewable, energy, savonius, power, pm, SAVONIUS ROTOR, Vertical Savonius rotors, windmill, Darrieus, vertical axis wind , vawt, hawt, windy, magnets
Step 1The wheel
the wheel
  • last photo ←
i got the wheel from garage sale a dollar a wheel.
the size is 29" diamater and 1" thick with 36 spoks
the wheel is 5.5lbs.
i am not sure if i am going to use the gear for the generator so lets not make a special placment for that reason.
so all 3 wheel should be the same size and 45.5" in between them.
the top and bottom wheels you need to remove 2 spoks every other 4 spoks
but the middle you need to remove 4spoks and leave 1 and so on.
that is it for the wheels for now, maybe later i need more work on them to brace 3 wheels together.
make sure you grease or oil them for better result.
faroun
16 comments
Mar 28, 2011. 1:41 PMjoshiewashie says:
Wow this is really awesome! I have just started learning about vertical axis wind turbine and I really want to try and build one just to see if i can do it. This really inspires me to try it and see if it will work for me. Thanks for the instructions! I love this site. So many fun projects to try.
Mar 19, 2010. 11:43 AMmahesh.ganpate says:
very nice to u your idia  i will be make 500watt vartical axis wec  dc genereter pls send me alternet details and drawing
Sep 5, 2009. 2:31 AMskylover7 says:
could you explane how you built the three pase genorator i am trying to make one too nice job. sky
Sep 22, 2008. 2:21 PMbhunter736 says:
I like what you have done! : ) You are getting a meaningful amount of power from very little air movement too. That is very significant. I like the view of the yard too, it makes the VAWT look as much like an aesthetic addition as a resource.
Aug 10, 2008. 9:51 PMwatkinsbl says:
This is great! Congrats! Several questions. How did you figure out the the number of wings, their length, and the size of the leading edge? How did you make the base - secure the bottom wheel? Have you ended up generating power from this? How did you hook it up and to what? Thanks Brad
Aug 11, 2008. 10:30 PMwatkinsbl says:
wow! 25watts @ only 5mph, that seems way above what others have reported, especially given its ground level location. You did 6 wings on the top and 6 on the bottom, right? How did you cut the PVC pipe in half lengthwise ( that seems like a major feat to me). Why an Ametek; they seem pricey?
Thanks for both of your inspiring Instructables!
Brad
Mar 29, 2009. 5:39 PMmred2 says:
"i konw that my instructables are not the best written but i am doing my best." are you kidding me! You have tons of pictures and closeups of things and they are not blurry! I see alot of things that should have more angles of shots of a project, but they don't....so keep up the good work! Although I am curious of the brand of pm generator, and did you buy it, or scrap it out of something? If so, what'd you rip it out of or cost if purchased? The 3 phase motor. What does it look like? How did you make it custom and same question for this motor as above. Thanks and keep us updated.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:faroun(Wrapwind)
