3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Faroun Lenz v2 Vertical Axis Wind Turbine
Step 2The Wing
The Wing
  • last photo ←
the wing is made of 2 parts, the wing surface and the wing leading edge.
the surface I used
floor lamminate' 4.4" long .25" thick, 8.25" wide and it is 4.5lbs
the leading edge is PVC tubing
3" PVC cut in 2 and 5' long 2.1lbs
i started by screwing the lamminat to the wheel first.
when the screwing was done, i then placed the pvc as the leading edge, i notched the pvc to fit through the wheel rim.
at this point i have screwed the PVC in place using few screws only, for further testing. i did try diffrent layout but the best so far is the 2/3 leading edge on the inside and a 1/3 to the outside of the lamminate board.
regards
faroun
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:faroun(Wrapwind)
