so i am taking that chllange to create my own style of Savonius wind generator.
in this Instructable i will include the steps that will achieve my Faroun Savonius Wind Mill.
the size over all will be approx 6 feet high and 2.5 feet wide
split into 3 main steps and each main step will split into mini steps.
Note:: that the sound that you hear in the movie is the leaf blower that is producing air to turn the wind turbine.
3 main steps are:
-Turbine assembly =TA
*blades
*discs
*shaft
*bearings
*assembly howto
-Cage assembly =CA
*top, bottom and sides frame
*wind deflection
*mount on a fixed roof or tower
-generator and battery assembly =GBA
*generator
*Rectifiers and battery connection
*testing
sure things may change a bit along the way but you will be the first to know.
bellow is the semi-final product for Faroun Savonius
so lets start.
Faroun
Remove these ads by
Signing UpStep 1Turbine Assembly / Blades
material,Size,shape.
in my Project i decided to use Aluminum for Material but u can use steel, Puck Board, or even a simple 5gal pale cut into 2 or 45gal drum cut into 2, so many options you have for the blades.
the size for my blade is 12.5 width, 6.25 depth, .125"thick, 20" circumference and 18" high.
i did not cut or roll the blades i bought them that way, yes i am lazy..lol... i was going to do it with 5gal pale cut into 2 but i figured i want to spend a bit of money just to see the max i can get.
so i have 9 blades, 3 in each section. each blade takes a third of the disc area. so each 3 blades sandwiched between 2 discs (discs are my step2).
faroun
sam
regards
Not to be rude, but your knowledge on the subject of electromagnetism is a bit thin to be building a generator. All your logic is sound, but a deeper understanding will take you very far. It is mostly mind-numbing stuff but a long grind through it all is worth your time.
You may also want to use Word or some other program to double check your typing. Sometimes in a complex explanation, a single wrong word can really change the entire idea of the sentence. And being someone who is annoying enough to correct people often - I recognized many spelling errors. You will be appreciated greater if you convey your ideas in a more professional manner.
Design wise, a Savonius turbine, like other vertical axis wind turbines (VAWT) are designed for simplicity, reliability, and not having to change to face the wind. By adding wind "funnels" you do increase efficiency in several directions, but you also end up greatly decreasing efficiency in other directions.
Also, one thing to remember with belt drive systems. They rely on FRICTION to operate. And as I am sure you are aware, friction is the greatest enemy to efficiency. Well lubricated gear systems or a chain and sprocket system end up more efficient and more reliable, making up for the added difficulty in construction.
One last thing to this now lengthy comment. I have always designed things with a thought left in my mind by an old high school teacher: KISS (Keep-It-Simple-Stupid). Oddly enough, the SIMPLER the design ends up, the better they seem to work. If it is not necessary to the end goal, remove it.
I may be only 16 but hopefully I will soon be the possessor of several patents for various things I have designed. I wish you the best of luck and happy building.
you are correct, I do have a problem spelling and not explain my design correctly.
since this design a I have moved on and have invented few different vawts and hawts.
also, I have built 12 serpentine axial flux, not traditional coils.
please check me out at youtube my name is emagnets.
http://www.youtube.com/user/emagnets?feature=mhum
regards
sam
You mentioned you had to have a 10 mph wind to produce anything worthwhile... I found that If you use smaller gauge wire in your coil the magnet can travel slower by the coil while still producing (almost) the same power output....
I'm sure someone out there has already worked out the math on all of this but from experimenting I found the thinner gauge wire to produce better results at lower RPM as well has higher RPM.
Again, great work, thanks for posting!
thanks
sam
regards
sam
you will find all my video. you should check out my latest "Column turbine"
regards
sam
2 questions where did you buy you're magnets and how much and
was placing the magnets so hard because it was attracting to the plate or to each other?
their prices are ok.
the magnets were difficult to install, they were attracted to each other.
regards
sam
I have used them before, and they are set up a bit different than what you used.
It involves using 6 diodes, and should improve your setup by at least 15 percent. There is a web site that shows it here...http://www.allaboutcircuits.com/vol_3/chpt_3/4.html Hope this helps, Steve
Thanks afbcom for the clearifications, i am not pro at this, so please correct me if i am wrong. others need to do it correctly.
regrads
sam
there are few more ideas on how to coil winding on youtube, seach for them.
regards
sam
regaRDS
SAM
This looks like a great project!
If your interested in topics like this feel free to check out my forum on “Sustainable Energy”
At http://www.voltsandboltsonline.com/index.php
regrads
sam
regards
