Step 14PM DC motor generator mount
i simplified 2 ways as you will see in the photos and the movie.
one way is to use a V belt with 5 to 1 pullies.
the other way is to get timming belt and a wooden disk 3/4" and place portion of the belt arround the cirunfrence glued on, place it on the turbine and the smaller pully that you can get at the junk yad too mount it to the dc motor, you will see in the pics and movie what i meam.
i liked the timming belt better it was less drag and qiuter.
they both produced about 12.25 volts at 80 rmp witch is i am assuming 10mph wind. i know i know soon i will be taking the beast outside, finally sring is here and the snow is gone i hope for few month...lol..
regards
Not to be rude, but your knowledge on the subject of electromagnetism is a bit thin to be building a generator. All your logic is sound, but a deeper understanding will take you very far. It is mostly mind-numbing stuff but a long grind through it all is worth your time.
You may also want to use Word or some other program to double check your typing. Sometimes in a complex explanation, a single wrong word can really change the entire idea of the sentence. And being someone who is annoying enough to correct people often - I recognized many spelling errors. You will be appreciated greater if you convey your ideas in a more professional manner.
Design wise, a Savonius turbine, like other vertical axis wind turbines (VAWT) are designed for simplicity, reliability, and not having to change to face the wind. By adding wind "funnels" you do increase efficiency in several directions, but you also end up greatly decreasing efficiency in other directions.
Also, one thing to remember with belt drive systems. They rely on FRICTION to operate. And as I am sure you are aware, friction is the greatest enemy to efficiency. Well lubricated gear systems or a chain and sprocket system end up more efficient and more reliable, making up for the added difficulty in construction.
One last thing to this now lengthy comment. I have always designed things with a thought left in my mind by an old high school teacher: KISS (Keep-It-Simple-Stupid). Oddly enough, the SIMPLER the design ends up, the better they seem to work. If it is not necessary to the end goal, remove it.
I may be only 16 but hopefully I will soon be the possessor of several patents for various things I have designed. I wish you the best of luck and happy building.
you are correct, I do have a problem spelling and not explain my design correctly.
since this design a I have moved on and have invented few different vawts and hawts.
also, I have built 12 serpentine axial flux, not traditional coils.
please check me out at youtube my name is emagnets.
http://www.youtube.com/user/emagnets?feature=mhum
regards
sam
