Step 6Cage Assembly/ Wind Deflection
i simply biult the cage and then covered half the turbine where the blades are comming backwards, the reson to cover them is to eleminate the drage that the back of the blade create, also i am in the middle of adjusting the deflection method to be more productive in tunneling the wind twards the desiered area.
take a look at the rendering that i have created.
faroun
regards
I feel that I am disappointing some of my subscribers because I don't have accurate data, it is just that proper data needs more money and I am like most, only spend what I can. I hope I do better in the future.
some said that my v8-4" can and will produce 150watt in 35 kmh wind but all I got so far is 22watt at 24kmh wind when I did the test using ametek 38vdc. with presto alternator results should change dramatically but presto will cost me $325.00 and that for now is not an option. SO if you are handy and able to spend few dollars, please feel free to built my turbine for personnel gain only and see if it can produce 150 watt.
note that my V8-4" is on display at Harvard GSD Ecological Urbanism exhibit.
go to http://wrapwind.com for more info
regards
