3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fart Operated Random Channel TV Remote
OK, I know that sounds weird, but bear with me for a moment.  My Pops really enjoys two things; 1) channel surfing and 2) farting.
So one day I was over at http://hackaday.com/ and read about a guy who used his Arduino to turn a TV on and off with one of those brainwave reading headsets.  Then later on that same day I was here at Instructables and a fellow had made an office chair that twitters every time he farted.  So, I got to thinking and decided to mash those two hacks into one remote that changes the TV to a random channel every time he tutes!
Plus, if you throw it in a plastic enclosure and hide it between the couch cushions, you've got a purdy dang good prank!
(As an aside, I've done some internet searching and I think this might be the first flatulent operated remote control in the history of the world... I'm happy to be an innovator.)
*****VIDEO UPDATE*****
You asked for it, here's a short video of the remote in action.
Step 1Parts And Sketches
Parts And Sketches
The idea here is you have a Methane sensor that smells a fart, then sends a high signal to an Arduino that picks a random number (which will be your new TV channel) and then sends the correct light pulses to an Infrared LED to change the channel.  So to do that I'm going to break up the components list into two parts.  Part One is all set up components and Part Two is stuff that's actually going to be a permanent part of the project.
Miscellaneous Parts:
Arduino (I use a Duemilanove... $30-$35 depending on where you buy it.  I bought mine from Make: as part of a kit http://www.makershed.com/ProductDetails.asp?ProductCode=MSGSA which comes with a Tactile Switch.  But a cheaper option might be to go to Spikenzie Labs and buy an Arduino/Switch combo from them http://www.spikenzielabs.com/Catalog/index.php?main_page=product_info&cPath=12&products_id=40 is the Arduino and the switch is linked lower)
Prototyping shield ($12.50)
http://www.adafruit.com/index.php?main_page=product_info&cPath=17_21&products_id=51
1/4-Size Breadboard ($4)
http://www.adafruit.com/index.php?main_page=product_info&products_id=65
(Or you could replace the ProtoShield and 1/4-Size breadboard with a solderless breadboard)
1X Working TV with,
1X Working TV remote
Part One Components:
1X 10K Ohm 1/4Watt resistor ($0.99 for a 5 pack)
http://www.radioshack.com/product/index.jsp?productId=2062347
1X 100 Ohm 1/4Watt resistor ($0.99 for a 5 pack)
http://www.radioshack.com/product/index.jsp?productId=2062339
5X 15 Ohm 1/2Watt resistors ($0.99 for a 5 pack)
http://www.radioshack.com/product/index.jsp?productId=2062310
1X Momentary Tactile Pushbutton Switch ($0.35)
http://www.spikenzielabs.com/Catalog/index.php?main_page=product_info&cPath=34&products_id=185
1X 38kHz Infrared Receiver Module ($3.95)
http://www.parallax.com/Store/Sensors/ColorLight/tabid/175/CategoryID/50/List/0/SortField/0/Level/a/ProductID/177/Default.aspx
Part Two Components:
1X CH4 Methane Sensor ($29.99)
http://www.parallax.com/Store/Sensors/GasSensors/tabid/843/CategoryID/91/List/0/SortField/0/Level/a/ProductID/592/Default.aspx
1X Infrared LED ($1.99)
http://www.radioshack.com/product/index.jsp?productId=2062565
(Some of the resistors from Part One; I'll explain this in a later step)
Optional:
1X Plastic Enclosure (RadioShack sells them, but I was going to use one I picked up at Fry's a while back)
1X 9V battery and battery holder
Tools:
Multimeter (for calibrating your CH4 Methane Sensor)
So if you're starting from scratch you're looking at about USD$86.00.  I'm guessing most folks on this site and looking at this 'Ible already have the tools, Arduino and ProtoShield which would put the cost around USD$40.00 (A $34.00 CH4 Methane Sensor/IR Receiver Parallax order and a trip to RadioShack for resistors/IR LED).
Sketches:
Sketches are linked on the steps that they are used in.  I did my best to document and put notes into my code but I'll be happy to explain anything that isn't clear.  Just ask.
68 comments
1-40 of 68next »
Apr 7, 2012. 2:17 PMWalrus For Hire says:
Have you officially named this amazing creation of yours? It needs a name worthy of its ingenuity and awesomeness. The assmote?
Dec 18, 2011. 10:38 PMdudesurge says:
i have an arduino nano from http://www.dealextreme.com/p/arduino-nano-v3-0-81877 its uber cheap the only down side is it takes a while to arrive but its worth the wait and kinda wanna make this at some point
Nov 25, 2011. 10:52 AMlesizz says:
Totally deranged. I Love it!
Instead of connectting to a TV, one could connect to claxon horn and flash warning lights and switch on a fan. Never sneak one by again.
Sep 15, 2011. 5:16 AMalmamater says:
LOL its great for zapping
Jul 25, 2011. 7:28 AMNE patsrock says:
was that a REAL fart????
Jan 31, 2011. 3:46 PMBuild_it_Bob says:
Hello Schmidtn,
I am using 0021 and an Uno . I read some more on line and in the end copied into Hyperterminal. I didn't copy it right ( it was late at night) so the code didn't work right. I will try again and keep you posted .
I also wanted to compliment you on your step by step approach to putting a project like this together and testing it as you go along...very wise! It also makes it much easier to trouble shoot each step as opposed to when the project is complete and a puff of magic smoke is all there is to show for it.
Thumbs up and bravo,
Build_it_Bob
Feb 3, 2011. 7:56 PMBuild_it_Bob says:
Sucess using Hyperterminal and copy paste . I just had to make sure the commas were correct and then it worked for a samsung tv power off/on command . I removed power from the arduino , re-powered and tried it again a few times and it worked each time . This is something that can now be expanded and used in other projects !
Yea Team!
Arduino coupled with good instructables ( and teachers!) make for awesome learning.
Many Thanks!
Build_it_Bob
Feb 2, 2011. 2:27 PMfranspaco says:
hahaha good one
Jan 30, 2011. 6:23 PMBuild_it_Bob says:
I am trying to "Copy" the readings and can't seam to highlight them ?? Is there a step that i am missing?
Thanks for your help with this as i was able to to decode my Sherwood RC-119 remote by disconnecting pin 11 every time I seen the NEC 32 bit code come up on the serial monitor.
Build_it_Bob
Nov 27, 2010. 3:40 PMetopsirhc says:
most epic device ever made!
Oct 3, 2010. 6:18 AMPaulCote says:
Now put it in a chair :) it would be a funny prank xD Nice job!
Sep 6, 2010. 8:10 AMagis68 says:
prrrrrrrrrrrrrrrrrrrrrr, prrrrrrr, prrrrrrrrrrrrrrrrrrrrrrrrrr,prrrrrrrrrrrrrrrr,prrrrrrrrrrrrrrrrrr,prrrr,=well job in electronics, change your diet, Instructables Admin open the f@T## windows!!!!!!!!!!!!!!
Jul 21, 2010. 2:34 PMlazyjoe21 says:
You should add a mode that changes the channel based on the intensity of the fart. Like channel 1 when its a silent but deadly and channel 999 for the loudest and longest in duration.
Jul 28, 2010. 9:37 AMkitik says:
Loudest and longest isn't always most powerful though. But the SBD should get extra points for its potency. Total fart power reflects a combination of 3 variables -- intensity, spread, and persistence. If there were a way for the sensor to reward farts that were terribly stinky, covered a large area, and/or lingered profusely, that would be the ultimate.
Jul 27, 2010. 12:23 AMriverreaper says:
what if theres multipul farts would it then channel surf for him?
Jul 22, 2010. 8:17 PMQuestor says:
NOW, we're talkin' I like where this is going
Jul 22, 2010. 8:13 PMQuestor says:
better than a "Clapper"
Jul 26, 2010. 11:35 PMPower23432432 says:
Speaking of clapper, that would be interesting to link it to the light's so the light's flicker when every they fart.
Jul 27, 2010. 12:44 PMQuestor says:
or mount the vibrating unit from a "Magic Fingers" to the frame of the chair they're sitting on . . .
Jul 26, 2010. 9:37 AMpollom says:
specially designed for this guy http://www.youtube.com/watch?v=qJDbLWROTII
Jul 22, 2010. 1:39 PMmichabailey says:
The problem is, many channels don't actually exist, and entering them gets you nowhere. What you would need to do is compile a list of all the channels that work, and have it choose from those. Of course, you could always set it to something specific, say, Nicktoons...
Jul 23, 2010. 5:32 AMmichabailey says:
Oops... *facepalm* Apparently I missed that... .
Jul 22, 2010. 7:34 AMdataboy says:
In Australia you can buy a fart remote unit from Jaycar for $12.95 AUD. http://www.jaycar.com.au/ Cat No: GH1088.
Jul 22, 2010. 8:16 PMQuestor says:
that is an electronic whoopee cushion
Jul 22, 2010. 7:44 AMvmod32 says:
That's not the same as this at all... Try reading things closer next time..
Jul 22, 2010. 8:43 AMMadCobbler says:
Not the same, but fart related. He was just trying to contribute. It's better if our maker family is nice to each other and less judgemental.
Jul 22, 2010. 2:58 PMDIY-Guy says:
Aw come on, Vmod wasn't being rude. Very diplomatic and neutral with a helpful suggestion. I'll take whatever flak ensues if my comment to the MadCobbler is misinterpreted. (This is not an attempt to "troll.") Have a great day Mr. MadCobbler!
Jul 23, 2010. 8:18 AMMadCobbler says:
No problem, just a difference of opinion. I just thought telling Questor to "read things closer next time" was a bit confrontational and making an assumtion on the intent and purpose for his posting. I felt Questor was not "off topic", but just providing info about another fart related gadget (admittedly not a remote, or in the same league though) for those that might be interested. Sorry if I have caused a stir, I certainly don't want to cause a distraction to Schmidtn's fine project. I'm done. - Peace out. -
Jul 27, 2010. 12:27 AMriverreaper says:
well a fart machien could be of use if your fartless an wanted to test it as your ajusting the settings or even if you just plainly wanted to swich the channel right befor a climax in a stupid show he was watching when you wanted to watch barrny the dinisor insted . just a thought ....
Jul 22, 2010. 6:53 PMynneb says:
Fartastic idea !!!
Jul 22, 2010. 11:17 AMmartzsam says:
This has to be the most ridiculously amazing inventions since breathing. I applaud your skill and humor. Good job. *****
Jul 22, 2010. 2:54 PMDIY-Guy says:
Agreed. Ridiculous, amazing, etc. But the breathing part is getting harder every time the sensor is triggered! Finally, something we *might* be able to call the first non-commercial use of Smell-o-vision. Keep up the good work everybody, between this and the "coin slot detector" we may be able to integrate warning lights into the back pocket design of future fashions- and save the rest of us from an assault from the rear! Phew! Enough!
Jul 22, 2010. 11:46 AMLinco says:
Got a vids? :D
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Schmidtn
Former custom bike manufacturer, spent four years as a spy and now I'm an Industrial Engineering student spending my free time thinking up things to invent that I think people will like well enough to...
more »
