3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fart Operated Random Channel TV Remote
Step 6Replace Tactile Switch with Calibrated CH4 Methane Sensor
Almost there, in this step we're going to replace the tactile switch with your calibrated CH4 Methane sensor and test everything.
Work to do on your sketch:
Download my PrankChannelCH4 sketch linked below, and again, replace my pulse codes with the pulse codes we know work with your TV (you used them in Step 4).  Also replace my channel list with your channel list.
And if you have an overly sensitive CH4 Methane sensor, scroll all the way to the bottom of the sketch.  Replace;
"delay(60000); //60 second debounce for fart to clear out"
with
"delay(300000); //5 minute debounce for fart to clear out"
Work to do on your Breadboard:
Leave your Breadboard the same as the previous step and:
Connect CH4 Methane ALR to Arduino digital pin2 (Do not plug this into Arduino pin2 until after the Arduino has been plugged in and the heater warmed.  This takes about 10 minutes)
Put resistor/IR LED circuit back in between Arduino digital pin3(PWM) and Arduino Gnd.
Connect your Arduino to your computer, upload the sketch, open the Serial Monitor, plug the jumper wire from your CH4 Methane sensor into Arduino Pin2 (after a 10 minute warm up) and you're ready.  Point the IR LED at the TV and break wind.  The red LED on the CH4 Methane sensor should light up, a random number should pop up in your Serial Monitor and a second later your TV should change to the random number in your Serial Monitor.
Congratulations, you have just recreated [what I believe to be] the first ever TV remote operated by farting.  You feel that?  It's not light-headed-ness from farting all day... that's success, my friend!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Schmidtn
Former custom bike manufacturer, spent four years as a spy and now I'm an Industrial Engineering student spending my free time thinking up things to invent that I think people will like well enough to...
more »
