Fast Fire Match Rocket
2,390
14
Posted
Introduction: Fast Fire Match Rocket
I made this rocket my first starting making the one match rocket then I decided to make a big one so I made this. I named it Fast Fire.
Some information before making the rocket
1. If you want to make the best rocket then increase the amount of the powder and aluminum foil.
2. If you want to make a rocket that flies less and then blast then use then increase the amount of powder and decrease the amount of aluminum foil a little.
Step 1: Materials
You will need:
Aluminum foil
Paper clip
Matchsticks
Tea light candle
Step 2: Making the Stand
For the stand you will need a paper clip. I not very good at explaining so follow the pictures.
Step 3: Separating the Powder
Use a scissor, nails or anything you want to use to remove the powder from the head of the matchstick. You can remove the powder into a container.
Step 4: Making the Body and Adding the Fuel
Put the piece of aluminum foil on a flat surface then put the powder in it. Take a match stick and put it in the powder then use a pin or the same paper clip and pt in the same way as you put the matchstick after that roll the aluminum foil with everything in it as shown in the picture.
Step 5: Setting Up the Launch Pad
Put the stand on the candle as shown and then put the rocket on the stand. Light up the candle if it does not light up then remove the rocket light up the candle and then put it back in the correct position.
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
If you need help ask me
