3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fast Handling Bike Trailer
Our family ride bikes regularly. We have an old 70's era Burley tandem that we added a tag-a-long bike to for outings. My two boys enjoy riding about anywhere. Their longest ride to date is about 27 miles. During the summer as gas prices spiked, we decided as a family to do some of our errands on our bikes. We added racks and baskets to all the bikes. However, for a grocery store run you need more holding power. So one day while puttering in the garage, I thought up a way to use the existing tag-a-long hardware to rig up a trailer. I looked at the assorted store bought trailers and the Instructables offerings and used the best of all the worlds. As with most builds like this, hind sight is 20/20 and I would do things a bit differently if I did it again. I am currently collecting parts for the next trailer that will allow me to carry even more.
Step 1Material List
Material List
Material list:
1 qty old bike fork
1 qty storage container of your choice. I used a 27 gal. Rubbermaid one from Costco
1 qty old bike wheel. The smaller the diameter the more it will tend to bounce over bumps
6-10 tech screws or any screw suitable for attaching your bin/container
1 qty child tag-a-long bike hitch. These are easy to make but so easily available why bother
? qty of wood for deck. What do you have laying around. I had a scrap of 3/8" plywood from another project
? qty of conduit, pipe, tubing or misc. metal. I used about 3 and 1/2 feet of 1/2" EMT electrical conduit and 3 and 1/2 feet of 3/4" EMT electrical conduit. I also used a small length of 1" square tubing because I had it and ran out of EMT. Use what you have.
4 qty pre-bent 90 degree elbows. You could weld straight 90's or use a tubing bender. I was going for maximum convenience in this step. They are pretty cheap from the hardware store.
4-6 qty bolts variety of lengths. I used some bolts to strengthen all the joints. I found misc ones that fit snug in the pipe, cut them to extend a couple inches into the joints and welded them all the way around. (probably over kill).
2-4 qty of plate steel. I used some scraps from my junk bin. They were brackets off some old equipment. The pieces I used were about 1/8" but you will need to use metal thickness based on the loads you intend to carry. There will be flexing at the joint if you go too thin.
Tools Needed:
Welder
Hack saw
File
Tape Measure
18 comments
Oct 18, 2009. 9:52 PMmykacanada says:
 well i now have the way to move all my fishing gear with me instead of taking my car thanx
Jul 9, 2009. 7:07 PMbbrown86 says:
Where did you get the tag along hitch? How much did it cost? Great build, thanks for the ideas!
May 30, 2009. 12:20 PMdodo91 says:
i was always trying to find a way to sell soda with having to carry it everywhere.
Apr 25, 2009. 8:15 PMforrest1st says:
thank you so much for this add i just built on almost exactly the same i just have to attach the wheel and connect to my bike
Jan 30, 2009. 7:09 AMHightimber says:
That's an interesting stoker pedal arrangement. Could you tell us a little about it? Thanks!
Feb 2, 2009. 7:46 AMHightimber says:
Thanks! That would be really cool to see some pictures.
Nov 28, 2008. 11:42 PMBobS says:
What is unclear to me is how the container/ flatbed stays horizontal. It seems there is only one straight tube running underneath, from the hitch to the fork. Can you explain what kind of construction to keep the flatbed at a straight angle from the wheel?
Jan 8, 2009. 6:56 AMscafool says:
I think the fact it overlaps the fork is what prevents it from rotating on the straight tube to the fork. I don't see anything else that would prevent it from tipping over if it was just on the tube and not resting on the fork head and tubes too.. I think he should have bolted it to the tubes of the fork he is using to hold the trailer wheel and maybe added some sort of bracing to it from the top bend or vertical section of the main tube. You are right, he is not very clear about that part of it..
Jan 8, 2009. 7:04 AMscafool says:
I think he was asking about how you attached the chipboard to a round tube and expect it not to twist the fasteners out when you load it. How the seat post mounted connector works is plain enough.
Dec 2, 2008. 7:01 AMomnibot says:
That would be the hitch. I allows movement up/down and left/right but not to twist.
Nov 27, 2008. 4:15 PMcrankyjew says:
cool. whats going on with those rear pedals? tall bike tandem monster in the making?
Aug 15, 2011. 6:48 AMcrankyjew says:
oh alright, that's cool, i've never seen those before.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:couchchangeracing
