What i hope to show you is how to make quick LED lighting that is on a TINY buget.
What you need :
Cable
LEDs
Resistors (510Ohms for 12V)
Stapels
Soldering iron
Cutters and other basics
Hammer and a nail!
(NOTES FOR n00bs)
LEDs need about 30 milli amps (0.03 Amps) or they burn out
To work out your resiance use:
V=IR
Voltage (V) = 12
Amperage (I) = 0.03 (30*10-3)
Resitance (R) = ?
SO :
V/I=R
12/0.03=400Ohms
or more...
i used 510 so my LEDs arent running at the brightest they could be
Remove these ads by
Signing UpStep 1Costs
Cable : 8.51GBP high grade white cable per 50m ($13.99)
LEDs: 6.18GBP (Cheaper by the 1000) (the LEDs i used are 13,000 and 6,000 mcd with a angel of 25 degrees)
Resistors x100: for 0.99GBP
Staples: Well cheap...
Which works out at:
0.89 per metre!
Spacing of 1 LED per 10cm is enough (get the spacing right or it looks strange)
which isnt bad for really nice lightening that on average the leds will last 11+ Years!
I used a power adapter i had lying about but anything that is 12V and lying about will do fine :-)
Just as a general rule you need 30mA per LED. (this isnt strictly true, but it will keep you within tolerences)
so if you had 20 leds you need (30*10-3)*20=600mA or 0.6 A
you can use any copper cable.
Ive been saving these babies from the trash at work for over a month and now I have over 30 feet of em. I think im gonna see if I can find some decent sized crown molding and go around my whole living room.
Cheers!
that would give you 12 - 9.9V = 2.1 V ( Instead , of a resistor , connect a smaller LED ) (and a small amount of resistance , usually )
It can be seen on http://www.LEDCalc.com/
What i did for my room lightning was 2 LEDs and 1 130 & 120 Ohm Resistor ( I Wanted more brightness , since it's my room , and i could replace led's quickly )
In each line .
Because it's 9V and 350ma From my wall-wart , i placed 17 lines of LED's , (34 LED's )
