3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fast hot glue mold for small things
Here I will show to you how to make a fast, simple and cheap hot glue mold to reproduce small things.
Step 1Materials
Materials
You will need:
1. Some oil
2. Hot glue gun
35 comments
Jun 5, 2011. 10:07 PMimBobertRobert says:
would i be able to reverse it? like use clay and use that as the cast, then put hot glue into that cast?
Jun 6, 2011. 1:32 PMdbrt60 says:
I think that it's possible. The clay must be a little more dry, maybe. Try it! Don't forget to tell me the result. :)
Jun 8, 2011. 5:56 PMimBobertRobert says:
it worked OK. the mold was hard to get out so i left a little bit hanging out and then cut it off. the clay crumbled after about 5 uses, but it was worth it!
May 23, 2011. 1:39 PMiminthebathroom says:
nice idea, I will remember this for the future!
Feb 1, 2011. 9:04 AMkenobr100 says:
can you do both sides or is it too hard to do?
Jan 13, 2011. 9:26 PMLadyBoi says:
I wonder if you could use this method for doing stamps? Just gluing the hot glue mold onto a piece of wood or cork... hmm, something to try...
Oct 8, 2010. 3:43 PMblah42 says:
would a army man work
Nov 14, 2010. 5:12 PMblackdragon27 says:
the little green action figure/ army guys
Nov 14, 2010. 5:11 PMblackdragon27 says:
what can u use besides oil?
Oct 30, 2010. 5:55 PMdawsonj says:
nice!
Oct 11, 2010. 11:10 AMcefn says:
So obvious in retrospect but I'd have never thought of it.
Another technique to add to the arsenal, thankyou.
Oct 3, 2010. 1:45 PMCriket says:
(removed by author or community request)
Sep 26, 2010. 7:05 AMvacuforms says:
Super idea! Easy to follow instructions! Thanks!
Sep 22, 2010. 7:42 PMAsmodeous says:
hmm, is this borderline counter-fitting?
Sep 21, 2010. 9:08 AMRobot Lover says:
This is great! Just a tip, don't use bondo to fill the mold because the bondo mixed the excelerator will get so hot that it might melt the hot glue. 4.5*
Sep 21, 2010. 4:21 PMRobot Lover says:
It is a putty used for cars but can be used to fill molds. If you want a better explanation here is the wikipedia page. http://en.wikipedia.org/wiki/Bondo_(putty)
Sep 15, 2010. 8:57 PMdchall8 says:
I see some necklace pendants in my future. Thank you!!
Sep 15, 2010. 11:02 AMtheblinddonkey says:
awesome.
Sep 15, 2010. 11:59 AMFrankenPC says:
I think you just committed a felony ;-D
Seriously, that is cool. And easy to do.
I bet you could lay down a layer of glue on a warming plate, put down the object and lay another layer on top to create a complete mold. Just use a bit of oil on the bottom layer of glue so you can separate the two halves.
Sep 15, 2010. 10:12 AMscoochmaroo says:
Wow, this is great! I never thought of doing this before. How many times can you use the mold before it deteriorates and loses detail?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:Lindsley(Hololab)
