Faux Black Opal Cast Resin Earrings
2,165
40
6
Posted in CraftJewelry
Introduction: Faux Black Opal Cast Resin Earrings
About: Geeky artist. MUST. MAKE. STUFF. More stuff at: rhondachasedesign.com
Black opals are one of the most valuable gemstones because of their rarity and dark, iridescent beauty. I've been working on casting realistic faux gemstones with resin and have come up with a black opal I'm really proud of. Since I work a lot with natural gemstones, realism is important to me.
Aside from the enormous difference in cost, one of the great parts of using resin is you can make your opals in any shape or size. I've decided to use heart post earrings to show you my technique.
Step 1: What You Need
A bezel or bezels of your choice (see the next step to help choose)
Casting resin - any kind works fine, it's mostly just a matter of drying time (I used polyester)
White glitter (not fine, you'll want some texture)
Pearl powder colorant
Black enamel (nail polish is fine)
Iridescent acrylic or enamel paint - 1-3 colors
Tweezer
Toothpicks
Wax paper
Mixing cups (Dixie cups work well)
Lots of patience
Step 2: Bezel or Mold?
There are generally two ways I cast faux gemstones using resin.
The first is to pour resin into a mold and pop the "gems" out when dry. This means the lowest parts of the design are what shows on the front when removed from the mold.
The second casting technique I use is to pour resin into a bezel, which like a flat mold with a small lip. When pouring into a bezel the bottom of your design stays on the bottom. Resin stays in the bezel, which means you can make the "gem" the exact size of the ring, pendant earring, etc, that your making.
For this tutorial I've chosen to cast my opals in tiny heart bezels which are attached to earring posts. You can make your faux opals project using any size or shape bezel. If you decide to use a mold instead, remember you'll have to reverse the coloring steps.
Step 3:
Set your bezels up on something nonstick, like wax paper.
Since I’m using post earrings, I am poking each post into a piece of foam to keep my earrings stable.
Step 4: Base Color
For each bezel, paint a heavy coat of black enamel (nail polish) on the inside. While the enamel is still wet, sprinkle in white glitter using a tweezer. Repeat this for all the bezels you’re working with. Push ornery pieces of glitter down with a toothpick.
Allowed to dry fully.
Step 5: Small Batches
Do a few at a time so the enamel doesn't dry with out glitter.
Step 6: All Filled In
Step 7: Highlight 1
Now pick a color of opalescent paint - it can be either enamel or acrylic. And with a very tiny brush or your finger dab a very small amount in each bezel. The color should be very random. Do not overwhelm the black and glitter you already have.
Step 8: More Highlight Colors
Add one or two more colors, one at a time, very lightly.
Step 9: Wait
Allow everything to dry fully again.
Step 10: Ready for Resin
I rearranged my earrings to make pouring resin easier. Note the wax paper.
Step 11: Resin Layer 1
Mix a very small batch of resin (enough to fill 1/4 of each bezel). Add in a tiny amount of pearl color. The resin should still be see-thru.
Note: Prepare resin according to package directions
Step 12: Pour
Add a thin layer of pearly resin.
Step 13: Adjust
Use a toothpick to push the glitter into the resin and push the resin around.
Step 14: Resin Layer 2
Mix another small batch of resin and keep it clear. Add a thin layer. It's okay if this mixes a little with the first layer.
Allow the resin to set.
Step 15: Fill
Mix another batch of clear resin. Carefully pour to fill each bezel.
Step 16: Dome
As the resin thickens, slowly add one drop of resin at a time, until the surface forms a dome. Try not to overfill and drip over the sides. It's easier to add resin later if needed.
Step 17: Check
Look at the sides of the bezels and make sure all the tops are domed. Add more resin to any that are too flat. Try not to touch or move these now. (Some people put a dust cover over the wet resin.)
Step 18: Wait
Now be patient. Allow the resin to cure fully. The surface should be glassy and smooth. If you touch it too soon, you'll leave fingerprints. How long this takes depends on the resin and the temperature.
Step 19: Keep Waiting
Step 20: Don't Touch Yet : )
It's tempting, but touching too soon will dull the surface.
Step 21: It's Time!
Check over your bezels. If you have any imperfections, you can add more resin. If you have drips, sometimes you can gently pick them off.
Step 22: Ready to Wear!
Just add earring backs and your black opal earrings are ready to wear!
If you enjoyed this tutorial or just appreciate the effort : ) Please vote. Thanks!!
Casting Contest
This is an entry in the
Casting Contest
    • Flowers Challenge
      Flowers Challenge
    • Spotless Contest
      Spotless Contest
    2 Tips
    Great tips! Thanks!
    I have a bunch of eyedroppers, but keep forgetting to try them. I will get to it :-)
    Embedding rhinestones (and crystal) doesn't quite look like opal, but can look pretty awesome. I often set up a whole array of items to try in the resin and keep tabs on what works. It's kind of like creating recipes.
    Thank again!
    The trays that deli companies deliver sandwiches and fruit trays make great dustcovers.
    You can get disposable eyedroppers on ebay about 10 cents each if you get 100. Walmart, newegg also have them. This may be easier/faster than pouring. If you leave a clear hole when done a stage, you may be able to use them 2-3 times.
    As an alternative to fauxopal, look at putting small rhinestones in the bottom of the bezel, with or without a tint in the casting resin. A tint makes the stone 'lurk in the mists'
    2 Questions
    Where can I find your black pal earrings?
    Hi Rhonda. Is this a powder? What is it called? (I.e. product name, manufacturer)
    Hi! I use acrylic paint (any brand from any craft store) and/or nail polish. Both of these work well with resin. They don't bleed and they come in great colors. I hope this helps!
    6 Comments
    These look great. Reminds me of NASA pictures of deep space nebulas.
    Cool, you're right! Another idea to play with : )
    Thanks!!
    I always end up with bubbles. :/ still learning. And need patients!
    Bubbles are definitely a problem. There are some things to try to help reduce them:
    1 tap the mold gently - tiny bubbles will rise and you can pop them with a pin or try scooping them off
    2 heat - heating resin with a heat gun or hair dryer can bring bubbles up to be popped
    3 be gentle - stir gently when mixing resin (I don't do the pouring back and forth thing, it makes too many bubbles)
    4 let resin sit - after mixing, let the resin sit for a few minutes so bubbles can rise, then scoop them off
    Let me know if you find any of this helpful!
    Also, I'm working on a faux amber tutorial in which bubbles are your friend. I'll have it done in the next few weeks :-)
