Faux Fur Using Yarn
7,121
53
13
Published
Introduction: Faux Fur Using Yarn
About: I make a variety of projects on instructables. I enjoy making flea free soaps for my dogs and have an interest in candle making and painting/drawing. I also enjoy to cook and bake and crafting. Enjoy taking...
This is a way of making fur without guilt and very cheap
A year ago, I made faux fur tails using yarn for my kids
I also wanted to make plushies for them but faux fur is very hard to find or expensive
I looked online on how to make faux fur in fabric form and many sites showed up on making faux fur with feathers?
And even using masking tape and yarn
That reminded me of the faux tails I made using yarn
Of course, you could use real, but I wouldn't kill an innocent animal just for it's fur
I then started experimenting and came up with a way of making faux fur with yarn
You can use this faux fur for making Halloween costumes, sculptures, clothing, and even plush
Step 1: Materials
Yarn -Any kind would work (I used inexpensive yarn)
Scissor
Scrap fabric ( in the color of the yarn you are using)
Sewing machine (would be more stable) or fabric glue
Cardboard scrap
Wire brush
Step 2: Making Each Fiber
Making each fiber is actually very easy
Take your yarn and lay the end down on your work surface
Pinch the end and put it to the opposite side (see pictures)
If you want long or short fur fibers, they will be in half
Keep bundling the yarn until thickness desired
It is best if the bundle of yarn is thin is you are using glue but any thickness can be used for the sewing machine
Tie the middle of the bundle with yarn
Cut each loop at the end and group the yarn again
Using the wire brush, brush the yarn fibers until a soft fur like texture appears
Step 3: Making the Faux Fur Fabric
Cut the yarn that is holding together the bundle of yarn at the end of where it is tied
Do that to each yarn bundle
Cut the fabric to the size that you need
Sew or glue the yarn bundle at the top of the fabric in a row closely together
Continue until the first row is complete
To do the next layer, Take a heavy object and flip the fur and weigh it down so it doesn't get in the way
Glue or sew the next row of bundles just above where the bundles of the first row meet the fabric
Make sure the next row of bundles is very close to the first row of where it is sewn or glued
Continue until the whole fabric piece is complete
After the rows are done, Shake the fabric freely
Check to see if the fur fabric looks full
If not, sew or glue the middle of the yarn bundle sewn so the fur looks more stable and does not show
Or cut the yarn bundle fur so that it is short
This will make the faux fur fabric look nice and fluffy full
If you do not want the fur fibers flying around freely, iron down the yarn bundles in the direction the fur bundles are
Step 4: Results
This is a very easy way of making faux fur fabric
This costs very little and can be used to make plushies, decorate clothing, and anything else
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    13 Comments
    This is brilliant! I have just made some using my carder and I am thrilled to bits with the results. Thank you for sharing your creativity.
    Would it be possible to use this method to create fuzzy yarn?
    I like this idea very much, way better than using the real fur, and a lot cheaper in cost. Thank you. I will be trying this.
    So looking forward to using this technique to create fur textures for my dolls and small figures. Lovely :-)
    m
    Nice! I suggest using acrylic yarn if you want longer fibers. Also, for softer fur you should straighten with a flat iron on low temp. :)
    Thank you! I used an iron instead.
