Introduction: Faux Silencer
Picture of Faux Silencer
how to make a fake silencer
Step 1: Getting Materials and Tools
Picture of Getting Materials and Tools
Gather these items:
  • An Airsoft pistol of your choice
Materials:
  • Metal Conduit
  • A Highlighter
  • & two CD's
  • Tissue
Tools:
  • A rotary Tool or a drill and preferably a press of some sort
  • Super glue or a strong glue like it
  • A 3/32" drill bit
  • Needle Nose pliers
  • A saw frame
  • A saw blade (for cutting metal jewelry blades work like charms)
Step 2: Preping the Highlighter
Picture of Preping the Highlighter
  • Get your highlighter.
  • Remove the back of it .
  • Take out the ink cartridge.
  • Flip your pen around remove cap the proceed to pull out the felt tip .
  • Then cut of a piece of the nozzle 3/8" is left.
  • Then with you drill or rotary tool drill six columns of holes around the case of the highlighter.
Step 3: Getting Your Conduit
Picture of Getting Your Conduit
  • First measure the straight section of your highlighter.
  • Then grab your uncut section of conduit and mark on it how long it needs to be.
  • Get your saw and frame and proceed to cut off your conduit piece
Step 4: Cutting Your End Caps
Picture of Cutting Your End Caps
  • gGet your CD's .
  • Measure your conduit onto the center of your CD's and mark with a writing implement.
  • Drill a hole on the edge of your line.
  • Then proceed to cut with your saw.
Step 5: Assembleing and Finishing
Picture of Assembleing and Finishing
  • Get all your parts and your super glue.
  • Get your highlighter case and wrap your tissue paper around it so it is as flat as possible.
  • Then slide into your conduit twisting as you go.
  • Then glue on your end caps and depending on how clean your cuts were you may need to sand the edges of your end caps but i didn't so you might not have to.
  • Get your paint of any choice probably black and get it to match your guns finish.
  • your done
Deltaforce2555 (author)2008-08-04
It's not illegal because that would not work on a real firearm. And yes it is a fake suppressor because it will not suppress an actual firearm.
Pbyrd (author)Deltaforce25552008-08-05
Well thats how real silencers are made,though.
llamatard (author)Pbyrd2012-02-11
nope, they are made w/ washers and pipe....not tht i have made 1...
Pbyrd (author)2008-07-24
Well this is ilegal because this isnt a fake silencer as you say it is, it's a real one.
I wouldn't make these anymore because of that reason. But still a good instructable. I just wanted to let you know that these are real so you wouldn't get into trouble making these.
nightcreep20 (author)Pbyrd2008-12-30
As long as it has blaze orange on the tip its not illegal.
llamatard (author)nightcreep202012-02-11
not illegal anyway, just highly advised :P
daelans (author)Pbyrd2009-05-10
its not like it can silence an airsoft gun that much, unlike real guns, airsoft doesn't propel bullets using expanding gasses caused by an explosian. a silencer works by dispelling these gasses (to make it simple) and in an airsoft gun (every single one ive seen in reakl life, even ones i didnt use) , one, did not shoot like this, and to most of the noise came from inside the gun. therefor this cant silence an airsoft gun very much, possibly a gas a little bit, but mostly just muffle, there for is a muffler not a silencer.
AnarchistAsian (author)Pbyrd2008-08-13
it's not illegal if it can't be used on a real gun. he used fragil cd's that would break away if used on a gun. the atf couldn't charge you with any crimes.
zombiekiller42 (author)2011-01-10
I have a Giock 17 but a painted it.
very nice. yeah i was happy with mine.
Mine is a cyma.
sharlston (author)2009-07-25
in the last step it looks like a pink co2 cartridge with holes in it lol
daelans (author)2009-05-10
is there supposed to be sound in the video?
i have a question, hows it attach to the gun, does the highliter slip in the barrel? cause that would block BBs, i already have a silencer but the tip of the gun i want it on is not threaded so i need to know how to attach it straight.
also, in yours you didnt need the holes all that much. just more realistic, correct?
chicks dig me (author)2008-09-11
i need one of these because im an airsoft asassin($35 a hit,depending on the mission).
Matt21497 (author)chicks dig me2009-04-01
Woo u could get rich off of a single match
chicks dig me (author)Matt214972009-04-06
sort of, i usually do local stuff but still. o and leave a message 4 me on my orange board and ill usually respond in a week or 2
TyIslander (author)2008-11-02
what size conduit do you use?
footer0 (author)2008-09-25
My glock 23 serial number is the safety :P
AnarchistAsian (author)2008-08-13
k thanks
where'd you get the pistol?
twenglish1 (author)2008-08-06
who cares if its legal or not nobody will care if you have an airsoft gun with a silencer
About This Instructable
10,918views
15favorites
License:
More by cyprian916:Special forces helmet from an old flashlight and an old bike helmet.Homemade Medieval Letter OpenerM1903 Spud gun rifle
Add instructable to:
