loading
Step 4: Step #4 more paint
So now is time to paint. Using a foam brush and paper plate for your palate, paint your metallic acrylic paints however you want. Again, we are on the inside, stay within the lines now!
I used metallic acrylic paints for two reasons.
First, it looks more authenticly like stained glass and second is provides more privacy.
The metallic properties have a two way mirror effect when used this way. They reflect light when a person is looking in, therefore blocking any view to the inside and not reflecting light for the person on the inside. Letting us see who is outside our door.
You can use any technique you like, but making wavy streaks and splotching will enhance your stained glass fake-out.
Let dry.
You are now done. How easy.
<p>I want to use puffy paint for this purpose also, does it have to be &quot;sealed&quot; so it stays on the glass? like perhaps when i am finished going over it with a clear polyurathane or something?</p>
In my experience I have not had so seal it. I always painted the inside so the weather wouldn't bother it. It is pretty much waterproof unless it gets soaked. If you want to permanently keep your design then sealing it might work but I would recommend just letting your paint dry and not worry about it.
<p>How much scrubbing is necessary to remove the paint so you can repaint? </p>
There will be a some scrubbing. I found it easier to wet a sponge with soap and water and get the paint moist, then go at it with a plastic putty knife. It is removable and I have reapplied several times but there will be a bit of scrubbing like I said.
Excellent! Looks like something I have to give a try.
<p>Would have loved to see how much light comes inside the home from the sunlight with these paints. All in all looks great and thank you. </p>
<p>Nice idea of changing a boring window in a fancy window. We can <br>also use spray paints and do some abstract art to give a funky look to the <br>window. Try it guys.</p>
Hi! Nice job! I did this once on a &quot;broadcasting live&quot; bathroom window. I even made it match my lil rug and shower curtain. Just so you know, you can also do this non-permanently! There's a line of paints and &quot;leading&quot; from Gallery Glass. The nice thing about that brand is, if you ever tire of the design or change Colours inside, you can peal the whole thing right off. You can even re-stick it. Handy for shower doors if you move!
Thanks for the feedback. Glad that you also figured out a way to paint glass! It sounds like you missed the beginning of my instructions that let you know that this is a non permanent craft technique, so don't be afraid to go crazy. I also used the acrylic paints because I found the gallery glass paints to be 3x expensive and actually harder to remove from my window.
Thank you mercurycrest! a few of the pics show how much light is coming through, but I see that they aren't the best pictures to demonstrate lightage. I will see if I can dig some pictures out to show you all what it looks like from the inside. I have since removed this particular pattern and replaced it, but I can assure you that it lets in plenty of light. I didn't use a lot of dark colors and if you use the metallic type of paint it will be more like frosted glass than anything, even with the reds/greens/ect. Happy painting! ps I mixed some of the paints with a little water to dilute and make different shades.
Very well done. <br> <br>I just picked up some old picture frames and am about to stain them in a similar fashion. <br> <br>I'm curious as to the amount of light your technique lets through. Could you perhaps post a picture from the inside-looking out- on a sunny day?
Fantastic, I have done this many times before using those same craft paints, but here's a trick. Mix your acrylic paints with water soluble varnish. Now a little goes a long way 1/8 cup of varnish only needs about a teaspoon of paint for the desired effect. You will have beautiful colours with a nice level of transparency. The only problem is the folk paints are quite opaque to begin with, the best way is to ask for tiny little amounts of paint tint from a paint shop. Use this stuff even more sparingly. It will shine with a translucent like jewel quality.
excellent cost saving idea.... thanks!
I like the varnish idea. I'll have to try that. I always mix a little dish soap in. The windows I keep painted crank out so I can spray them down and squeegee them when I am ready to start again. My daughter just did a wonderful winter scene for me.
How do you remove it? Are the paints you used water soluble?
These paints are water soluble and very easy to take off. I had the same paints on the same window for over five months and used a wet rag and soap and water. I did need to do a little scraping with a razor blade on the thicker areas but really easy to remove. Have fun!
I love it! So beautiful!
Wow, that looks great!
Great job, that looks really nice!
You can rotate your photos on your home computer (go to thumbnail view, right-click and select either &quot;rotate clockwise&quot; or &quot;rotate counterclockwise&quot;), and then re-upload them to this project without having to start it again (you, as the author, should see an &quot;edit&quot; button near the top-right of this page).
Thank you. I had a duh moment when you pointed that out! all fixed!
Cool.
About This Instructable
90,961views
177favorites
License:
Bio: Porklips? What are those? Those people, are lips that have let pork come near enough to leave oily juices. Something that I am not fond ... More »
More by porklips:Easy, decorative dry erase board project Gluten-Free Ramen Cheater 5 Minute Forever and a Day Air Freshener
Add instructable to:
