loading
loading
Picture of Faux Stained Glass Windows
easy to do, easy to remove! how can you go wrong with these 'stained glass' windows?
Step 1:
Picture of
gather the supplies:
Windex, paper towels, acrylic paints in the desired colors, skinny masking tape and a sponge brush. you'll also need a bowl to put your paint into.
Step 2:
Picture of
start out with a freshly cleaned, dry window.
Step 3:
Picture of
use masking tape to make your pattern. i made diamonds. press it FIRMLY to the glass.
Step 4:
Picture of
using the sponge brush, apply the 1st color. i chose green.
use a dabbing motion to apply the paint to the window.
Step 5:
Picture of
allow the 1st color to dry, and then apply the next color. i used red. use that same dabbing motion.
Step 6:
Picture of
allow the window to dry thoroughly. then carefully and slowly remove the masking tape. pull the tape straight off the window, to pull in any other direction could cause the edges of your pattern to chip slightly.
you could fill in the clear areas in the pattern by painting them black, but i like to leave them clear.
Step 7:
Picture of
there you have it, faux stained glass windows. they look gorgeous from the outside at night, and beautiful inside on a bright sunny day. they provide extra privacy and by blocking out some of the sunlight keep your room cooler.
as an added bonus, they throw a very cool light and shadow pattern onto the ground outside at night!
i like the blotchy effect of sponge brushes and dabbing-you may like a smooth appearance. if so, simply substitute a soft, long bristled brush for the sponge brush.
and think of the possibilities during holidays!
best of all, if you grow tired of them, they're easy to remove with some Windex, a razor blade and paper towels.
i hope you enjoyed my new instructable, and have fun!
camatteo1 year ago
I'm thinking of trying this on clear laminate cut into inserts to cling to the windows of my classroom. That way I won't catch heat for damaging the building, and I can remove them. Alternately, I'm thinking of printing onto transparancy stock...
artquilter5 years ago
There is 1/4" masking tape if you wanted a narrower line between.  It's sold at art supply and quilting shops.
cloner5 years ago
love it! al experiment with my aquarium! :)
can this kind of paint be removed? how?
like what if u found a new cool design and u'd like to change it.
how long does d paint last til it fades in color?
tnx
susanfromhauntspace (author)  cloner5 years ago
thanks for the comment. it can be removed very easily. i simply spray a little Windex on it and use a razorblade. it peels right off in long strips. the red and green was the 2nd color i've done my windows, they were green and orange before that (for Halloween a year or so ago)
about fading...it depends on the amount of sun the window gets. the ones on the south and west of my house fade in around 6 months, the others fade more slowly.
not bad! i hope i can find windex here! :) tnx
drawe21 cloner5 years ago
I'm sure any glass cleaner would work fine.
MaxineLaRue5 years ago
I love this! I make real stained glass but can't find the time to make panels for all the windows I want to in my house. I'm going to do this on one of them, it looks like so much fun! Thanks for the idea. :)
ChrysN5 years ago
That looks really cool, are you using regular acrylic craft paint, or do you need something special for glass?
susanfromhauntspace (author)  ChrysN5 years ago
thanks! it's just plain old acrylic craft paint!
Joe Martin5 years ago
That's a very good effect, On you first picture it almost appears the the glass is bevelled in the gaps in between the colours. 5*
susanfromhauntspace (author)  Joe Martin5 years ago
thank you!
