Faux Pewter Trinket Box
490
24
Posted
Introduction: Faux Pewter Trinket Box
If you love the look of pewter, using aluminium tape as an alternative is easy and inexpensive and you can buy a roll at your local hardware store. This trinket box is intended as a gift for a friend who loves pewter work, and I love working with aluminium tape. The top of the trinket box has a layer of thin aluminium sheet so that I can apply an engraved poem easily using my Dremel MultiTool.
Step 1: Make the Box and Lid
1. Assemble the box by gluing all the sections together. Clamp and leave overnight.
2. Use the lid of the box as a template for cutting thin, sheet aluminium to fit. Draw around the lid but cut the aluminium sheet slightly smaller than the size of the lid. You need to do this in order to attach the pine moulding around the edge later on. You can use a jigsaw and blade for steel to cut the aluminium sheet, or a Dremel MultiTool and cutting wheel.
3. Use a craft knife to cut and peel away a width of film on the sheet (if there is any) that is as wide as the pine moulding you will be attaching later on. Don't remove all the protective film as this avoid the surface from being scratched.
4. Use a strong glue or adhesive to attach the sheet to the top of the lid.
Step 2: Box Detailing
5. Aluminium tape only comes in one width, so to overcome any visible joins along the sides of the box I divided this into 3 sections. The middle section is as wide as the tape and then there is a small strip at the top and bottom.
6. Using a puffy paint pen the design is also split into 3 sections and this will disguise the seam. Use the puffy paint pen to apply a design over the sides of the box. I went with a simple floral design, but you can apply your own choice of design.
7. Let the paint harden before applying aluminium tape. Although I show that I started at the top - start with the centre strip and then apply the top and bottom edges.
8. After applying each layer use your Dremel MultiTool and #422 polishing point, or use an ear bud, to ensure that the tape is flat around the detailing.
9. Use a sharp craft knife to cut away excess tape. The top edge was applied last.
Step 3: Engrave Top
10. Now you can peel away the tape on the aluminium sheet on the lid to do your engraving.
GOOD TO KNOW: Print out designs and wording from the Internet. Make any adjustments so that it all fits on the aluminium sheet, after allowing for the frame that will be glued around the outside edge.
11. Using a #225 flexi shaft and #105 engraving cutter to make an initial outline through the template. Lift the securing sellotape from time to time so that you can check to see that the wording is clearly shown. Be patient and take your time with the individual letters.
12. After outlining the wording remove the template and repeat with a #106 engraving cutter. The daffodils were outlined with permanent marker before engraving with a #106 engraving bit. Wipe clean with a soft cloth and WD-40 or mineral turpentine.
13. After cutting and gluing the frame onto the lid, this was covered with aluminium tape. You could apply the tape to the frame before gluing it down.
Step 4: Apply Vintage Effect
Finishing:
To give the aluminium tape a vintage or aged look apply black craft paint over the tape. Make sure to fill all the detailed areas.
Before the paint has time to dry, use a paper towel to wipe away the paint, only leaving paint in the detailed areas. You can repeat this if you prefer a darker effect.
The finished trinket box. I haven't yet decided whether to mount silver hinges at the back or add corner braces on the underside of the lid.
Visit me on www.Home-Dzine.co.za for more craft and DIY projects.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
Amazeballs. It looks great without the distressing, but after… !!!
