Introduction: Fedtro Vacuum Tube Tester to USB Conversion
Picture of Fedtro Vacuum Tube Tester to USB Conversion
Well, I basically took the tester and removed the battery spacers out that were obsolete
Due to the size of the battery which was slightly smaller by a 5th of it. I then took an old Phone usb and usb adapter charger and clipped the micro usb connection off exposing the internal wires I then soldered the negative to negative and positive to positive and ran several test to confirm if is usefulness it worked like a charm.
tested the tester by plugging it into the outlet and computers even my car and it worked :)
so here you go enjoy
a Fedtro Vacuum tube tester circa 1966
To USB Conversion.
robot797 (author)2015-10-15
this isnt a real tube tester
it is a fillament checker
it checks the fillamtents
XD
Democon (author)robot7972015-10-15
Filament Checker Tube Tester
Tester is commonly used including by the maker so yes its a tester maybe not the tester you want it to be but it is a tester. :) thank you
robot797 (author)Democon2015-10-15
i know but i like to warn people about it
becaus i was fooled by it once (when i just started working with tubes)
To bad the technology is so great even at its age it is so much fun the image you have as your avatar what is that
robot797 (author)Democon2015-10-18
it is my firsth oscilloscope
i got it for free from a co worker
i had to dismantle it affter a year of service
it stoped working
Democon (author)robot7972015-10-19
omg I would work on it if it was mine. I actually had a hughes mitchell VFO i purchased online circa 1939 it was pretty busted up but I fixed it up really nice bought it for 90 sold it for 200.
Democon (author)Democon2015-10-15
is that a vintage oscilliscop? man its a beautiful piece
robot797 (author)Democon2015-10-16
realy
you think that
Democon (author)robot7972015-10-16
cant really tell without my glasses
ah that explains
BeachsideHank (author)Democon2015-10-16
You are both right to a certain degree, it is technically a filament continuity tester, the most likely part of a vacuum tube circuit to fail. More electronic circuitry is required to determine gain, leakage, and other useful information about a tube (valve for our Brit friends). My teenage buddy and I used to make these back in the '60's to test tubes from old television and radios we salvaged. For more comprehensive data, we would take them to a local food store which had the big console type tube tester that would check all parameters. I recall we used the venerable #47 6.3 volt mini- lamp as the indicator. That jeweled lens cap is a keeper, they don't make 'em like that any more.
Thanks for sharing :)
amberrayh (author)2015-10-15
Nice fix. Thanks for sharing!
Democon (author)amberrayh2015-10-15
your very are welcome.
About This Instructable
537views
11favorites
License:
Bio: I love Technology with a passion its constantly changing on a daily basis. This phenomenon is so overlooked by the most of the world we ... More »
More by Democon:Fedtro Vacuum Tube tester to USB Conversion
Add instructable to:
