3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Felted Recycled Beverage Coozie
Step 7Multiple options
Multiple options
OPTION ONE: While you're cutting one coozie, it is just as easy to cut multiple pieces at this point. Consider using up both arms of the sweater. Also consider consuming that beverage. It is probably getting warm by this point.
Choose which top and bottom aesthetically fit together, and check for fit. The cuff can be larger or smaller than the circular bottom portion, but will gather more at the bottom if there is variance between the two portions.
OPTION TWO: At this point also assess how much extra felt you'll have from the body of the sweater. For every 7 x 5 inch piece of felt you can cut from the leftovers, you can make another coozie. Simply sew together the 5 inch ends by using the sewing techniques as described in Step 8. Cut a circular bottom for this piece and proceed to the next step. The green coozie at the beginning of this project was executed in this way.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:juleej
Knitter/Crafter/Kode Warrior
