Introduction: Felted Wool Balls Braclet
This braclet is relaxing and great for a lazy day around the house. Have fun with colors patterns and designs!
Step 1: Supplies
STEP 1
You will need: • a few different colors of wool roving
• a towel
• a bowl of hot & soapy water
Step 2: Making It Wispy
STEP 2
Spread out your first roving color so that it is very wispy and thin but still connected.
Step 3: A Rough Ball
STEP 3
Form the roving into a rough and wispy ball. Do not squeeze though!
Step 4: A Bit of Water
STEP 4
Splash a little of water onto the ball... lightly though.
Step 5: Start Rolling
STEP 5
Start rolling the ball between your hands VERY GENTLY while adding a little bit of water every so often and little squirts of soap in your palm (not to much though) until it starts to condense and get a little bit harder.
Step 6: Like This
STEP 6
Keep rolling until its about this size and fairly tough.
Step 7: Repeat That Process
STEP 7
Keep doing this until you have 6-7 balls.
Step 8: Wash and Dry
STEP 8
Wash the soap out of the felt balls and set out to dry.
Step 9: For the Bracelet
Step 9
You can make another project with your felted balls of make them into this bracelet.
For the bracelet you will need: • your felted balls
• a needle
•a string of elastic that fits around your wrist plus an inch or two
• spacer beads (buttons look cool too!)
Step 10: Making the Bracelet
STEP 10
Thread your needle and tie a knot at the other end. Then, stick it through the ball and pull it tight. Put your spacer bead/button on next.
Step 11: Continue and Tie
STEP 11
Repeat this process until you reach the desired length or run out of beads. Then... tie the two ends together and you're DONE!
Weekend Projects Contest
