http://www.youtube.com/watch?v=zKMFEkSKGHg.
These only took me 2 days from start to finish. The next 3 pairs will be FASTER now that I know what I'm doing!
Remove these ads by
Signing UpStep 1Step 1 Supplies
I wear a Woman's US size 8.5, so I decided to go with the suggested size block for a size 9, which was 20 single crochet stitches across, and 20 rows for each block. I probably could have made it a little smaller, and it still would have been OK.
NOTE: I had VERY little left over from each shein of yarn (the supply picture shows how much was left), and in fact, had I done this in the pattern shown on the video, I would not have had enough of one color. IF you wear a larger shoe than this you WILL need more than 2 skeins
2 skeins of 100% wool yarn (I used Patons Classic Wool 100g/3.5 oz)
scissors
Crochet Hook (I used a G) US
Yarn Needle
Washer
Dryer
OPTIONAL
Sewing Machine
A yarn that is up to 50-60% wool, and then some other fibers, SHOULD work, but you may need to wash it more times and for much longer each time.....like resetting the machine instead of letting it finish the cycle.
Did they shrink at all? I had to wash mine 3 times total, since they don't get as much aggitation with a front load washing machine, like mine. Did you put something heavy in the wash with them, and wash them on really hot water? Did you dry them in the dryer on HOT?
When they are properly "felted" or shrunk, they have a much different texture than pre wash. You really can't even make out the seperate stitches, since the fibers all kind of meld together.
I'm so sorry you're having this problem....it sure takes the fun out of it doesn't it? Write back and let me know. Other wise I'd say try to unravel your stitches and use the yarn for something else :-(
Mary
