Fiber Optic Heart Rate Monitor
Introduction: Fiber Optic Heart Rate Monitor
This project creates a visual representation of your heart rate and can be used for monitoring the intensity of your work out or to simply make a great fashion statement.
Fiberoptic wire connected to a programable RGB LED light takes the input from the pulse sensor and creates a colorful translation of that readings. With this project you can literally wear your heart on your sleeve!
Compression sleeveArm Band
Heat shrink
Fiber optic cable (whatever size you'd like)
Hot glue/gunThread and needle
Flora Neo pixel RGB LED
Pulse Sensor
1000um capacitor
5 vol resistor
Step 1: STEP 1 : Programming Your Arduino
Download Pulse code onto arduino and test to run using a bread board
Make sure that you understand how your pulse sensor is working and if you need to allow for changes in your calculations
Program the arduino for the LED along with the Pulse sensor
This is the code I finally got to work. It blinks blue for pulses from 0-50. Green for 50-100 and red from anything above 100.
Step 2: STEP 2 Putting Together the Electronic Components
Once you have tested your connection you may begin to solder. I used a board and some connector to make a removable covering for the arduino. This was the arduino can be removed and used again in other projects.Soldered capacitor to connect with power and ground and then solder power and ground of the pulse sensor to the capacitor. Solder pulse input sensor to 0A port on arduino. Use a resistor between the power pin of the LED and the LED itself.Solder the the LED legs, positive, negative to corresponding legs of the LED.Solder to ground and then the out put to digital 5 pin.
Step 3: STEP 3 Fabricating Your Interface
Compile your strands of fiber optic cable and put the heat shrink around it. Make sure all ends are even and flush to each other
Heat the shrink material to hold the fibers tightly in place
glue the bundle directly to the LEDInsert fiber optics and pulse sensor into the bottom holes of the arm bandInsert Arduino board and battery into arm bandBegin getting creative, making designs or bending the fibers gently and hot gluing light points onto them. to your compression sleeve either using hot glue or thread and needle
watch your heart rate come to life blinking green blue and red
I tried to make an anatomical heart outline out of my fiber optic cables
Putting more points of glue diffuses it more and keeps the Light from fading. I guess that I will do less of that in my future projects for this topic.
Pull the sleeve carefully over your arm and the place the tune belt around your upper arms.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    This is a fun idea, I could see people using this in a dance fitness class :)
