Fidget Spinner Generator 3
Published
Introduction: Fidget Spinner Generator 3
About: new science projects, science experiments : rotating magnetic field device - research, small generator using a single neodymium sphere, fidget spinner generator, how to make a simple electric motor, pulse mo...
fidget spinner electric generator using 3 neodymiums spheres 13 mm, a coil iron -les and a led .
a sciencetoolbar.com http://sciencetoolbar.com
Step 1: Materials I Used to Create Fidget Spinner Generator 3
13 mm neodymium sphere - 3 pieces
coil iron - less - 1 piece
led - 1 piece
glue
plastic
Step 2: Operations :
attach the neodymium spheres to the fidget spinner
use the glue tu fix the coil through the plastic part on the fidget spinner
connect the led to the output wires ( iro - less coil )
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    2 Discussions
    You did what I had in mind :D
    Now, we have to found a way to store this energy and we will be self-sufficient ! No more climatic problem .... The world owe you a big deal man !
    first it must be improve. ( air friction, bearing, coil ( I used a cheap fidget spinner 0.5 $) . It is created in educational purpose like all other projects
