Fidget Spinner Made From a PVC Pipe
1,692
17
Published
Introduction: Fidget Spinner Made From a PVC Pipe
About: Innovative Projects, Diy's, Life Hacks
Whether you like it or not, Fidget Spinners are very popular at the moment. Some people use it as a toy, others to relieve stress.
If you want to make your own fidget spinner, this Instructable will show you one way to do it.
We will make a Fidget Spinner from a PVC pipe.
What's needed:
If you are Interested in the video version of this Instructable and the embedded video does not appear on your mobile device, here is an alternative link
Step 1:
I cut off a piece of PVC pipe.
Then I heated it up with a blowtorch.
Make sure to wear a respirator when heating PVC
When it was heated, I flattened it with a wooden board.
Step 2:
Then I drilled holes for marbles and a hole for a bearing.
Holes for the marbles should be smaller than the marble's diameter.
I also trimmed the pipe to desired shape and drilled decorative holes.
Step 3:
I reheated ends of the pipe, so they would open.
I inserted the marbles and half-closed the ends.
Make sure that the marbles turn freely (unless you don't want them to)
Step 4:
Then I put in the bearing
Step 5:
That's it!
Your Fidget spinner is ready!
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    Thank you. I never would have considered PVC for the frame of a spinner.
