3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Field Sink
Step 11Connect the Pump
Connect the Pump
 After feeding the Spout and Tubing  through the Spout Riser pipes connect the clear tubing to the tubing attached to the squeeze bulb pump. (or it could connect directly to the squeeze bulb but because I bought the bulb and hose as an assembly I wanted to leave the factory clamps in place)
The reason there are two sections of tubing is so that the unit can be disassembled for storage.  The upper clear tubing remains attached to the Spout as a friction fit.  There is no room for a clamp inside the smaller diameter upper Spout Riser pipe so the servicable connection is made under the Support Table.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
609
Author:hpstoutharrow
