Fifth Element stones with LED
 by speednsnake
This instuctable will detail how to make one of the stones from The Fifth Element. For each stone you will need: around 6 inches of wire, two springs, one AAA battery, a maker-bot, and an LED the color of the element you are creating.
Step 1: Body
First, draw an equilateral triangle with each side 40mm long. Next, boss extrude the triangle to 100mm. Now extrude cut a smaller equilateral triangle (sides 29.6mm) 25mm into the top of the triangular prism. close the cavity with an identical triangle placed over the top of the hole 3mm thick. Your stone should now look like this in cross-section veiw:
samc12345 says: Dec 19, 2012. 1:44 PM
Satrek says: Dec 19, 2012. 12:35 PM
Same here, they look good in theory (i.e. the model) and the idea of having these stones for mood lighting is great. Hope you get them done and share ;).
Penolopy Bulnick says: Dec 19, 2012. 12:27 PM
This sounds sweet! I'd love to see it if you ever get it made!
drogge says: Dec 19, 2012. 8:23 AM
Cool, Any chance of uploading the STL files?
randofo says: Dec 19, 2012. 7:43 AM
That's a great movie. I like what you have done here.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
