Step 3Assembling the housing
If that works, then fold along the indicated lines, wrap the tabs around the back, and attach the two tabs from the side panels to the rear panel. If you're looking from the back to the front, the place where the mirror will go should ramp up and away from you. You want to wrap the back tabs around the rear panel so that the 18mm hot shoe tab is facing down. The rear panel should be inside the tabs, such that the panel itself helps keep the folded at 90 degrees. You can see a picture of the back of mine. Note that I almost didn't leave enough space, and so my tabs are pretty small. (The flash is harsh because I didn't have the bounce unit on!)
Attach the tabs using glue or double sided tape.
Add Comment
